Old 11-17-2009, 04:16 PM
charv712  is offline
Posts: 307  -  iTrader: (14)
Tell me your recording gear...
Hey people, can you guys please give me a run down of the necessary gear used to record onto your laptop computers? Is what I need a..........1.Laptop........2.DAW program for laptop.......3.Audio Interface..........4.Miked guitar amp..........5.Guitar, and I'm ready to go?? Is that all? Also, if I have an ADA microcab, can I run a line from that to the audio interface in order to achieve my miked guitar sound? Any help would be appreciated. Thank you guys inadvance.
Old 11-21-2009, 02:29 AM
rhynobyte  is offline
Posts: 17  -  iTrader: (0)
Re: Tell me your recording gear...
Hey Charv. I started putting together a modest home studio about a 1 1/2 years ago and can share some of my experiences with you that may save you some time. I started with a dual core 500gb 2 gig ram system on windows Vista with Cakewalk MC4. I learned quickly that a decent interface is needed with good a/d converters. I found the reviews on the $200 - $400 products were very mixed and sometimes people get lemons. I settled with the presonus firebox because it was on sale. It has provided me with good clarity low and high more than enough volume and no backround noise. I have had no issues with this at all. Then I began getting some soft synths Like G force mini monsta and Imposcar, NI symohonic etc. I found them to have great sonic quality and they have never failed me either. I LOVE GFORCE synths.Then I got EZ drummer with most of the expansions. A little compression on the kick a little verb on the snare some eq and you can get great drum sounds.Then guitar rig 3. I also have Hardware synths that I use as well and some dated efx units that can come in handy. I had a couple of mics like the old reliable sm57 for micing cabinets and others. So I'm not looking to put together a million dollar studio here but I want faily great recording and here's what happened next equipmentwise. I started to write music and it was cruising along until I'd get to a point where I'd have 50 -75% of a songs tracks down and then drop outs. I was freezing midi tracks and my system was optimized to the max for what it was but nothing helped. Music creator and other beginner recording software doesn't utilze multi core processors. Not sure if the most recent cheapies do now but they didn't a year ago. Make sure you DAW recognizes multi core processors. Honestly make life easy and get a dedicated quad system right off the bat. I then upgraded to Sonar 7 HS. Fine for me I use a lot of external equipment and didn't see the reason too spend more money when I was using about %15 percent of the features on the DAW to begin with. I never had dropouts again. BTW from the beginning I never had latency issues with ASIO drivers either. I thought I was getting pretty good bass tracks with my American deluxe precision. Then I got a Fletcher era joe meek VC6 for $50 and discovered how fantastic an external compressor will make your tracks sound. For me it was everything. I've since very cheaply aquired a few differnet forms of compressors. For me the externals work better though I never did give the upper level software a good tester. Didn't need to after the externals. Old meek ,avalon ,Neve will absolutley bring your guitars to life acoustic ,electric they are key for me any way. I even use the transparent compressor on my yamaha mg to tame piano. I can remember when I got the meek and rerecorded the bass track on a tune I could now clearly hear the soft washing pad track that I was having trouble finding in the mix previously. Very key. Remember to scour the internet feverishly to find quality equip at dirt prices to attain the level of sound you desire. For monitors I use yamaha Ns 10 and edirol Ma 15 d. Yamaha of course are better but the eds give a different look. I also use beyerdynamic and audio tech headphones. I have this system coming out of home streo speakers and a 40w 2.1 computer speaker system as well. I like to hear it coming out of different sources. I'll listen to the bass on everything even clicking the loudness button on the home stereo to see if it's too much low when that occurs the sub translates differntly so I like to hear it on that as well. I've since upgraded my comp system and am only now after almost two years starting to see the light at the end of the tunnel key points are as follows.
- get as powerful of a processor as possible and 4 gigs of ram
- get a good interface saffire, presonus (go for better a/d converters
over more features.)
-your gonna spend a little coin on monitors
- get a good set of cans that represent low freq well. Research the specs online
- Get a DAW that records well enough but don't go for the bells and whistles. multicore compatible
I think you mentioned using a rackmount pre amp. compressor>tube head >interface = great track. Watch your preamp levels since there will be two stages now. find the best balance. Nothing compares with an ace tube amp miced correctly in a good room but you can get very very close if your savvy.
Also remember higher quality monitors make a big difference but whatever monitors you end up with you need to listen to recordings you really like and aspire to sound like (sonically). Listen to all your music on these. Your old stuff new stuff. That is why they are called reference monitors. Play some guitarist you really like their recorded tone and see if you can acheive it to some degree referencing.
I've gone on long enough here. As stated recording is fairly new to me and I am a complete novice but I think I have jumped some hurdles. I am very patient and when I've decided there is something I want but it is way way too expensive I wait and scour and somehow have got stuff for nearly nothing. Hope this helps.
Scour Man. Theres good stuff cheap out there.
Mark
Old 11-21-2009, 02:31 AM
Mark
Old 11-25-2009, 12:03 PM
SonicProvocateur  is offline
Posts: 1,104  -  iTrader: (0)
Images: 3
Reviews: 39
Old school!
Edit: 1969 Sony TC-630 Reel to Reel. Nickname "Angry Robot Face"
Old 11-29-2009, 06:27 AM
560licious  is offline
Posts: 322  -  iTrader: (0)
Images: 4
I don't record on a computer, I use the following: Fostex VF80ex 8-track recorder,
ZOOM Rhythmtrak-RT-223(drum machine), Behringer C-3 condenser mic,
Behringer Xenyx 1202fx mixer
Old 12-12-2009, 09:55 AM
LGMT  is offline
Posts: 364  -  iTrader: (0)
Waste your money in acoustics. Worth a lot. Hardware and software are nothing without decent treated room and good monitors.
Old 12-12-2009, 08:58 PM
Fantomas  is offline
Posts: 51  -  iTrader: (0)
Using a quadcore with 4 gig of ram and 2 terabytes of storage on windows 7
Sonar 8 to record
Recording through a podxt as interface
Drums: ezdrummer, addictive drums (for the quick jams) or fl studio/superior drummer for the more intricate parts
Guitar rig (software) and a bunch of hardware effects that i managed to pick up through the years for guitar effects,
iZotope Ozone 4 for mastering
No fancy monitors since I have neighbours, so just a Sennheiser hd212Pro headphone instead
What I have learned though: you can record great tracks with a crappy computer and free software.
The main factors are
1: compose something worthwile
2: mastering
3: mastering
4: mastering
You can always record, even on the most basic computer with freeware applications. It will take some time if you dont have the hardware since youll be forced to process all your effects and drums before actually recording, but its doable.
But mastering is where your song will shine or fail.
Old 12-13-2009, 12:38 PM
rty13ibz98  is offline
+10000
rich
Old 12-13-2009, 05:48 PM
Images: 3
Reviews: 39
Originally Posted by rty13ibz98 View Post
+10000
rich
Agreed, acoustic padding and top notch monitors are a MUST.
Don't skimp on a quality condenser mic either. Having 1 or 2 to chose from helps as well.
I also like using the Shure Beta mics, its a good compromise when mic'ing guitar and bass cabs or other instruments. (If you aren't DI'ing the amps)
Old 01-03-2010, 06:26 PM
purplemarek  is offline
Posts: 8  -  iTrader: (0)
i use a wax cylinder
Old 01-03-2010, 09:05 PM
Aris_T  is offline
Posts: 597  -  iTrader: (0)
Guitar->Pod Xt Live->Marshall VS102R->Shure SM57->Presonus Firebox->Macbook 2,4 4gb ram->Logic 9.
If I want to lay down some tracks fast, I just go directly from the Pod to the Firebox.
I use superior drummer 2.0 for drums and usually record bass tracks directly through the Firebox, using the Ampeg pluggin. No monitors yet (saving for genelecs), so I use AKG K141 MkII headphones.
Old 04-25-2010, 01:43 PM
rubislaw  is offline
Posts: 23  -  iTrader: (0)
Guitar-Amp- mic to M Audio interface- M Audio to Cubase Essential 5
Old 04-25-2010, 03:10 PM
not too big on padding as much as i am on bass trapping. i assume you mean foam over fiberglass insulation.
acoustic foam is used moreso in the control and attenuation of mids and highs and do nothing to control low end bass modes. your best bet is broadband absorbers. these types of absorbers take care of the majority of the frequency spectrum without sounding too dead. the thicker you can get them and the farther away from the walls/ceilings, the better they work. my traps are 4" deep, 4" off the wall and range in size from 3'x5', to 4'x6'. i have a soft ceiling in my control room with about 18" of fiberglass insulation and moving blankets to broadband absorb. further control with bass trap hung from the ceiling about 12" down as an acoustic cloud.
btw, i am not a fan of the shure beta series mics at all, the only exception is the beta 52 kick mic. i am a huge fan of sennheiser mics like the e602, e609, and e604.
if you want incredible bang for the buck as far as mics go, the audix i5 and SM57 are 2 workhorse mics for dynamics and the mxl v67i and apex 460 are killer LDC condensers for very little money that sound fantastic. spend the bulk of your money on room acoustic treatment and a really nice preamp(the GAP pre-73 and true P-solo come to mind), having one great channel will make mixing whatever project you do much easier and more fun.
rich
Old 04-25-2010, 03:43 PM
jemaholic  is offline
Posts: 2,806  -  iTrader: (14)
Images: 13
My man-cave...
laptop recording question
List your recording gear and your thoughts on your gear.. gemini8026 Recording Studio 39 03-14-2007 07:37 PM
FS/FT: Recording Gear! Jon_113 Classified Ads: Guitars and Gear 0 01-19-2007 02:14 AM
First recording gear ll Mr Blonde ll Recording Studio 8 03-28-2006 09:52 PM
Pictures of everyone's recording studio or recording gear rikkbeatty Recording Studio 38 08-22-2005 04:17 AM
got my recording gear. j.arledge Recording Studio 0 08-09-2005 10:55 PM
