Old 01-29-2007, 07:49 PM
newbieguitarmaker  is offline
Posts: 4,030  -  iTrader: (5)
Images: 1
trouble with my boss gt
I know i've posted about this before but so far no one on the boss forums or anywhere else have helped me. I have a boss gt-pro but it has lag problems in cubase se and the software for editing can't even find the device. I know i installed drivers perfectly but it just doesn't want to work correctly
Old 01-29-2007, 08:20 PM
guitvai1  is offline
Posts: 471  -  iTrader: (0)
Re: trouble with my boss gt
First off you must ensure you follow the directions to install the driver to a tee.
1. Before installing the software change the GT Pros driver mode to "USB: Driver Advanced" (press System then use the Parameter arrow buttons to display the driver mode, rotate the dial to select the mode above. Hit Exit.
2. Follow all instructions on pg 111 of the manual.
3. Ensure you are using the ASIO driver in Cubase. Personally I don't like using the midi interface to record in Cubase, I find it too difficult to set up properly. Instead I went out and bought a spdif digital cable and run that directly into my soundcard, it works perfectly.
Old 01-29-2007, 08:40 PM
Images: 1
i installed it like the manual and its running asio drivers, i think ill get a spdif cable but that doesnt solve the problem of the library/editor programs not detecting it
Need advice on use of Boss NS-2 Noise Supressor I just got steeda Gear and Equipment 15 02-27-2008 03:52 PM
FS: Boss BCB-60 Pedal Board W/ 6 Pedals DD-3, NS-2, etc... Robotechnology Classified Ads: Guitars and Gear 5 01-20-2007 10:42 AM
Line 6 Spider II vs BOSS gx700+Lab Series L5 amp? pera_a777 Gear and Equipment 2 12-13-2006 05:19 PM
FS/FT: boss pedals, carvin amp, duncan designed humbuckers tonluvara Classified Ads: Guitars and Gear 5 07-09-2005 01:11 AM
Boss gx-700 vs Line 6 POD 2.0? pera_a777 Gear and Equipment 0 05-29-2005 06:46 PM
