Recording Studio
Which instrument to record first?
Recording Studio
To discuss recording gear, home studios, home studio PCs, studio techniques and the likes.
01-08-2009, 07:33 PM
Andy43
Posts: 814 - iTrader: (
To me it seems like it should be the drums because that's the main rhythm part, but supposably it is hard for drummers to play the song to nothing, at least it is for mine.
What do you guys think?
Andy43
Find all posts by Andy43
01-08-2009, 07:47 PM
The Euphor
Posts: 2,948 - iTrader: (
Re: Which instrument to record first?
Nothing is stopping you from recording all at once, then redo the parts you are not satisfied with.
In a live situation (as in no MIDI parts) I prefer to have at least bass, drums and vocals. Vocals only as reference to where in the song you are. Also easier for bass/drums if they got more than a boring click to play to.
In the end, it's all up to you, really. What equipment you got. The players, what they prefer. How good the studio is, can you prevent bleeding during recording? One room, many separate rooms?
Only you know.
But, most drummers have a hard time recording over other tracks. As there most often will be small changes in tempo, and they are used to staying in charge.
The Euphor
Find all posts by The Euphor
01-08-2009, 08:01 PM
6fingers
Posts: 3,167 - iTrader: (
Reviews: 63
If you have a click track you can record any instrument first.
If not drums should be first.
If a drummer can't play the hole song alone because song have stops and stuff,ask to guitarist to record a guitar track following a click track..Just chord progressions for help drummer.
Anyway is always better using a click track expecially if song has fast and weird rolls and stuff cause you could mute drums and people will play over a click track.
6fingers
Visit 6fingers's homepage!
Find all posts by 6fingers
01-08-2009, 08:04 PM
The Euphor
I don't agree on the click track. For many styles of music, yes, but not always. Some music, even rock, can be very "organic" in tempo.
The Euphor
01-08-2009, 08:07 PM
6fingers
Reviews: 63
I said always because if drummer wants it,it's there,if not,mute it.
I just gave an option.
We don't know what he's recording and stuff.Well we know nothing so it was just an option.If a guy comes and ask about wich instrument should be recorded first it tells me he probably knows nothing about recording,even the basics so a click track would be a better option.Or not.
6fingers
01-08-2009, 09:28 PM
rty13ibz98
Posts: 1,811 - iTrader: (
34
you should try to play with a click. typically drums are recorded first, but with other musicians playing along. the other musicians are basically just going through the motions in order to get a "perfect" drum take. usually, those parts will be redubbed. those are typically referred to as scratch tracks. usually, as far as amps go, is this process, they are located remotely, or a modeller/plugin is used. this is to reduce the bleed from live instruments into the drum tracks. usually bass is DI'd. during this time the guitar and bass tones aren't as important as being solid with the drummer. most often, they will be overdubbed. as for singers, they are typically seperated from the group behind glass...either in the vocal booth or in the control room. in most project studios, that is a luxury we aren't afforded as much. in my 2 room, non viewing project studio i have right now, the scratch vox are recorded in a different room where the DAW(pc) is and the musicians are in the live room with the drummer. everyone works with a headphone mix. very crucial to reduce bleeding of extra sounds for the drum tracks. how i usually record is drums, then bass, then rhythm guitars, vocals, leads, the background vox. this is not standard as it is based around musician availability as well. as long as the drums are cut, or you have a solid click, you can start tracking any of the instruments.
rich
rty13ibz98
Visit rty13ibz98's homepage!
Find all posts by rty13ibz98
01-08-2009, 10:26 PM
OklaStar
Posts: 45 - iTrader: (
1. I always record the whole band,
2. Then kick everyone out but the drummer and have him play to a headphone mix so I have clean drums.
3. Then I record the vocals.
The guitars usually record great the first time, but I will often get a dupe of just the guitar so I can double it later for a thicker sound
Its much easier on the bands this way, its very organic and they are familiar with the process.
I only use a click track if they really really suck and I will have to do tons of cutting and pasting out bad parts.
OklaStar
Find all posts by OklaStar
01-08-2009, 11:47 PM
kotornut
Posts: 1,847 - iTrader: (
rty13ibz98
rich
This what I have always done. Record the drums but have at least the guitars and bass (and click track) playing along just to keep the drummer on task and in the mood. Then redub everything. But there are other ways to do it too. Click tracks are optional depending on the style, applicability and your drummers inner metronome, but I recommend them for just about everything in the studio.
I always did my scratch track with a POD. it worked well. Usually, a drummer needs to hear the guitar sound as real as possible so they can get into it. The last thing you want is a tight but uninspired sound. It's really hard to keep everyone emotionally charged on the songs when you are recording the intruments in segments and overdubbing things so be sure to try to keep that energy.
kotornut
Visit kotornut's homepage!
Find all posts by kotornut
01-09-2009, 12:04 AM
EvoGiant
Posts: 355 - iTrader: (
i always thought the accordion part went first....
EvoGiant
Find all posts by EvoGiant
01-09-2009, 12:32 AM
rty13ibz98
34
kotornut
we track scratch with pods and overdub DI into my pres, from there we either reamp or use plugins like gearbox or ampeg svx.
everything is just a bed for the accordian to lay in.
rich
rty13ibz98
01-09-2009, 12:35 AM
kotornut
rty13ibz98
rich
When I was cool and in a band and recording, we scratched with pods. And then recorded everything with live amps and good mics. We used mesas and marshalls for guitars, and ampegs and SWRs for the bass. The other guitarist (besides me) owned the studio and all the equipment we had a great time doing all this stuff like we were a "real band."
kotornut
01-09-2009, 12:58 AM
rty13ibz98
34
kotornut
i am basically the other guitar player in your last post! hehe i am the one with the boatload of gear.
rich
rty13ibz98
02-04-2009, 11:29 AM
shredmaster
Posts: 2,330 - iTrader: (
EvoGiant
NO WAY MAN! THAT'S THE ICING ON THE CAKE! it goes last!
i usually record drums first, and the drummer will record to a guitar scratch track, as someone said, to keep him in the mood. i have dealt with so many drummers and it's weird...they find it hard to play to a click track. and, they can't play a song all the way through on their own. rhythm guitar players don't seem to have a problem remembering parts and progressions but drummers do. for them, it's always a scratch guitar track to play along to. then rhythm guitars, bass, then leads...anything else...vocals last usually.
shredmaster
Visit shredmaster's homepage!
Find all posts by shredmaster
02-04-2009, 01:35 PM
skins345669
Posts: 835 - iTrader: (
shredmaster
Apart from accordion, that is.
skins345669
Find all posts by skins345669
02-04-2009, 01:55 PM
toneboy
Posts: 1,665 - iTrader: (
EvoGiant
No way man, you should always record the cowbell first because you can never have too much cowbell.
toneboy
Find all posts by toneboy
how to record on pc with pod
how can i record live with my pa?
what mic to use to record a guitar cab
how to record multitrack sound forge
which instrument to record first in a recording studio
VST instrument software for cubase (Mac)
Epicus Furor
Recording Studio
03:24 PM
Speaker or instrument cable?
iPig
Gear and Equipment
09:59 PM
Best Mic/Instrument Preamp for $50-$100
guitarman13
Recording Studio
04:15 PM
Best Instrument Cables??
adamcbest
Gear and Equipment
52
11-09-2004
08:19 AM
vst instrument question
FinnJ
Recording Studio
10:33 AM
09:38 PM
