Old 12-16-2012, 05:48 PM
AlaskaBat  is offline
Contributor
Posts: 8,948  -  iTrader: (18)
Images: 5
Reviews: 98
Re: Will a new soundcard solve my latency problem?
Originally Posted by ironfistx View Post
Now I'm even more confused lol.
"Warm up the signal" = give it more power? What are the pros and cons of doing that?
The Presonus has a tube in it--it alters the direct signal like any preamp.
The tube makes the signal sound warmer.
I think right now you should just think about an interface, and add other stuff later once you've done the reading.
Refer to Tweak's site.
All the info you need is there....and then some.
Use the left pane navigation to learn all about signals, routing, pre amps, recording, etc.
Old 12-18-2012, 01:21 AM
ironfistx  is offline
Posts: 765  -  iTrader: (0)
I have a keyboard now and the latency from trying to record MIDI still makes it unusable. It's like 128 ms.
Super bummed!
Old 12-18-2012, 03:58 AM
Contributor
Images: 5
Reviews: 98
Did you change sound cards?
All the keyboard does is transmit midi commands, if using the midi port.
A midi port does not send audio signals.
Please....please....please read through that link I posted for you--it breaks down all aspects of recording, interfaces, midi, audio signal paths, pre amps, etc.
It's going to save you a bunch of time....instead of waiting for replies.
Old 12-18-2012, 12:00 PM
No, same soundcard.
Two different people at two different stores both told me MIDI is much less intensive than processing audio from a guitar amp, so while an interface may be necessary for monitoring latency-free guitar, both people told me that MIDI would be no problem with just my soundcard.
Unfortunately, that is not the case
I also installed the ASIO4ALL drivers which, while recognized, do not give me any output.
Old 12-18-2012, 01:02 PM
I switched to the experimental Wasapi drivers in exclusive mode, and latency is down to 10 ms. I can still feel it a little bit but at least this lets me explore my new keyboard a bit.
They must be set back to the default drivers when you're done using Reaper or otherwise WMPlayer and other programs will give you errors.
Old 01-06-2013, 12:30 AM
RGTFanatic  is offline
Posts: 6,218  -  iTrader: (14)
Images: 3
I know I'm a couple weeks late on this thread, but I'm wondering what operating system your using on you computer? also processor, RAM, Motherboard.etc.....
I DID upgrade my soundcard to work specifically with my interface (Lexicon Omega: My review- http://www.jemsite.com/compare-softw...tudio/reviews/
I found that I have the best latency (4-5ms) working on WinXP and a clean 10,000 RPM hard drive.
__________________
Old 01-06-2013, 11:46 AM
fwd0120  is offline
Posts: 2,314  -  iTrader: (0)
Reviews: 4
Originally Posted by sebastian View Post
Have you tried using ASIO 4ALL V2 ?
This. Even on my netbook, I got only 10ms. I can play through amp plugins and not notice any delay at all. 10ms is unnoticeable. You can throw 1000 at ram and processor, but if your driver sucks, you'll always get latency.
Old 01-06-2013, 12:29 PM
Images: 3
Agreed, I HAD to buy a Creative sound card to get the Asio 2.0 drivers I needed to make the system work without latency. I'm working with an intel quad QX9650 and 8g of ram...that didn't help at all. however, working on XP is FAR more efficient than Win7.
__________________
Eventide H3000-getting around the latency Anthony Xander Gear and Equipment 0 03-06-2010 02:59 PM
Bored, let's solve the worlds energy problem with... Darin Off-topic / Miscellaneous 5 09-21-2007 08:16 AM
Please help solve my AI problems :) learningtolive Recording Studio 0 01-12-2007 06:54 PM
Panama+ Latency issues Dug Multimedia: Music, Pictures & Sounds 15 08-28-2006 09:58 PM
Audiophile and latency problems! Opeth Recording Studio 4 01-15-2003 07:42 PM
