Will a new soundcard solve my latency problem? - Jemsite
post #1 of 38 (permalink) Old 12-14-2012, 12:20 AM Thread Starter
I use Reaper and cannot reduce latency to a useable level with my stock soundcard. I cannot monitor what I record because there's a delay.
It wasn't an issue when recording guitar cuz I could just use headphones from my amp and hear myself playing in real time.
I want to start recording with a midi keyboard and it will be an issue because I won't be able to hear myself playing in real time, so I have to solve this latency issue now.
Is it a soundcard issue?
Computer specs:
Acer Aspire M3400
AMD Phenom II X4 820 Processor 2.80 GHz
8GB RAM (maxed out)
Windows 7 Home Premium 64bit
Soundcard is integrated so whatever the default one Acer uses.
I need to be able to hear what I'm recording in real time.
ironfistx is offline
post #2 of 38 (permalink) Old 12-14-2012, 02:28 AM
Reviews: 98
Re: Will a new soundcard solve my latency problem?
Get a good recording interface.
If you're recording straight into the sound card, then the sound card isn't zero latency.
You can find decent interfaces for less than $100 these days.
You can also get good used ones.
Check out PreSonus.
AlaskaBat is offline
post #3 of 38 (permalink) Old 12-14-2012, 06:53 AM
The DAW acts like a sound card.
Have you tried using ASIO 4ALL V2 ?
sebastian is offline
post #4 of 38 (permalink) Old 12-14-2012, 07:21 AM
new sound card and more ram always helps.
before i got my presonus firestudio, i used to mult out to a separate mixer and mix my recording track with that of my daw to reduce latency. with the presonus universal control; it is a convoluted, but very powerful signal routing matrix. no one(including me) notices a lag in the signal.
rich
rty13ibz98 is offline
post #5 of 38 (permalink) Old 12-14-2012, 11:41 AM
Reviews: 98
If you really need a new sound card anyway--go with a new, zero latency card.
If you're only contemplating one for recording--get an interface, as it has more features.
post #6 of 38 (permalink) Old 12-14-2012, 12:46 PM Thread Starter
Correct, that is what I'm doing.
Guitar --> Amp --> Signal split into headphones (so I can hear myself play in real time) and soundcard input (so I can record what I'm playing)
What are the advantages of an interface over going directly into a soundcard like I'm doing now?
Will an interface work with my current soundcard, or will I also need to upgrade my soundcard? And it will eliminate latency?
I know nothing about interfaces. What sort of things should I look for/avoid when choosing one?
My soundcard is fine otherwise, there's just latency when I turn the speakers on while I'm recording, hence me splitting my signal from my amp into headphones and into my soundcard.
post #7 of 38 (permalink) Old 12-14-2012, 12:55 PM
Reviews: 98
An interface offers other features, depending on what you get.
Some of these are: multiple inputs, headphone outs with volume control, level adjustment, tube preamp, etc.
Most are USB or FireWire, so they are not plugged into your sound card--they work separately.
All audio goes through the interface.
I have a Yamaha Audio gram AND a PreSonus Tube Pre.
Go check those out and see if the features appeal to you.
There are others, too--like the M-Buddy.
I like them because they are standalone, and don't rely on the sound card.
Keep in mind that the Presonus is just a preamp, though.
It can be connected to your computer, but will go into the sound card.
This is why I use both.
Guitar--Tube Pre--Audiogram--USB port.
post #8 of 38 (permalink) Old 12-14-2012, 01:36 PM
To be fair, I have my M-Audio ProFire2626 set up as my computer's default sound card right now, which is pretty much the norm, as I understand. With a good interface, you don't really need a separate sound card.
Drew is offline
post #9 of 38 (permalink) Old 12-14-2012, 02:52 PM Thread Starter
I don't understand how that is different from the other one? </noob>
So it goes:
Instrument --> amp --> interface --> USB port?
And Repear can read input from a USB port?
And there's no latency that way?
post #10 of 38 (permalink) Old 12-14-2012, 03:00 PM
Reviews: 98
That's what I mean--you can use an interface AS your sound card.
@Ironfist--they are 2 separate things.
The Presonus is just a preamp, but you can use it if installed into your sound card.
I use the interface for the USB connection.
Yes--it will integrate with Reaper.
Bunch of great info here:
http://tweakheadz.com/soundcards_and...interfaces.htm
post #11 of 38 (permalink) Old 12-14-2012, 06:11 PM Thread Starter
So probably the dumbest question ever but what is a preamp? The only experience I have with that term is the knob on some amps that says "preamp."
post #12 of 38 (permalink) Old 12-14-2012, 07:43 PM
Reviews: 98
All the info you need:
http://tweakheadz.com/midi_drum_tips.htm
post #13 of 38 (permalink) Old 12-15-2012, 12:31 PM Thread Starter
I don't think you meant to link to the midi drum tips page but that site does have some good info. I spent a while reading it last night. Thanks!
post #14 of 38 (permalink) Old 12-15-2012, 01:16 PM
Reviews: 98
Lol--no, but glad you navigated to the right stuff...lol.
Great info in there--should really get you started in recording.
post #15 of 38 (permalink) Old 12-15-2012, 01:51 PM
Reviews: 98
Anything you put between the guitar and amp, or recording device is a preamp--if it does anything to the signal.
The Presonus in my rig is just there to add some tube warmth to vocals.
You don't need it.
Just find a good interface.
What features do you want?
What's your budget?
I'll look around, armed with that info and find you some good ones....
Human Verification
Eventide H3000-getting around the latency Anthony Xander Gear and Equipment 0 03-06-2010 02:59 PM
Bored, let's solve the worlds energy problem with... Darin Off-topic / Miscellaneous 5 09-21-2007 08:16 AM
Please help solve my AI problems :) learningtolive Recording Studio 0 01-12-2007 06:54 PM
Panama+ Latency issues Dug Multimedia: Music, Pictures & Sounds 15 08-28-2006 09:58 PM
Audiophile and latency problems! Opeth Recording Studio 4 01-15-2003 07:42 PM
