Hi, im about to wire 2 humbuckers, tone zone bridge and paf pro neck, but have a few questions as ive never done this before. Ive only got a standard ibanez 5 way switch so i guess i can only wire both humbuckers in series? Ive looked at the dimarzio 4 conductor pdf file and it says i should solder the green and bare wires to ground ( back of tone or volume?) solder the black and white together and tape them off and solder the red wire to the hot connection, what is the hot connection? Also what wire do i use to connect the input jack? and what do i solder it to? Finally there are 2 wires not connected to anything, they are soldered at one end to the vol and tome pots and im not sure what they are for, ive attached a picture, do i need them? or shall i just unsolder them? Hope someone can help been meaning to solder these in for adges!
thanks
