Pickups & wiring
Advice sought on pickup choices - RG421->Vamp->PC
Pickups & wiring
12-09-2003, 09:31 AM
beyblade
Posts: 237 - iTrader: (
I'd like to replace the V7/V8 pickups in my RG421. They sound OK through a regular amp but don't sound anywhere as good through my usual recording/playing set up of going through a Vamp into a PC sound card which I use 100% of the time now. The Evo's in my 7vwh sound marginally better but I'm hoping there's a better solution. Someone once told me that active pickups work better in a direct to PC situation but I've never had any experience with EMGs.
I have no use for clean sounds nor split coils, mostly play solo's, only use one patch and it's full on shred distortion. I also would like to switch from bridge to neck while playing solo's and have a considerable volume increase without fiddling with knobs or changing patches. Maybe that means a weaker than usual
bridge pickup
Any suggestions would be much appreciated.
beyblade
Find all posts by beyblade
12-09-2003, 12:09 PM
Ibateur
Posts: 2,951 - iTrader: (
ToneZone Bridge, and Super 2 Neck?
I can't imagine a louder
neck pup
though I'm sure there is one out there.
But normally, a louder bridge is common, isn't it?
Ibateur
Find all posts by Ibateur
12-09-2003, 02:30 PM
The_Grindfiend
Posts: 668 - iTrader: (
Yes. The
neck position
is louder anyway, so if you have two pickups with the same output, the one in the neck is going to sound louder. You want to get a neck pickup that's slightly lower output than the bridge. This is one reason why the FRED bridge and
PAF Pro neck
work so well.
The_Grindfiend
Find all posts by The_Grindfiend
12-09-2003, 06:55 PM
beyblade
The_Grindfiend
Yes. The neck position is louder anyway, so if you have two pickups with the same output, the one in the neck is going to sound louder. You want to get a
neck pickup
that's slightly lower output than the bridge. This is one reason why the FRED bridge and PAF Pro neck work so well.
Dude, I've never heard that before and only observed it once in a
Les Paul Standard
. My experience is that the opposite is true. The bridge pickup is ALWAYS louder than the neck.
beyblade
12-10-2003, 12:46 AM
The_Grindfiend
bubbatan
The_Grindfiend
Yes. The neck position is louder anyway, so if you have two pickups with the same output, the one in the neck is going to sound louder. You want to get a neck pickup that's slightly lower output than the bridge. This is one reason why the FRED bridge and PAF Pro neck work so well.
Dude, I've never heard that before and only observed it once in a Les Paul Standard. My experience is that the opposite is true. The bridge pickup is ALWAYS louder than the neck.
It's probably because a lot of people use
bridge pickups
that are a lot hotter than the neck, and raise the
bridge pup
really close to the strings. But when you pick right next to the bridge, and then up near the neck, which one is louder?
The_Grindfiend
bridge pickup
bridge pickups
bridge pup
les paul
les paul standard
neck pickup
neck position
neck pup
paf pro
paf pro neck
pro neck
zone bridge
RG2610 one pickup?
how to put a chrome cover on my dimarzio pickup?
what is the best neck pickup
when to use middle pickup
Evo 2 is the best pickup of all
03:16 PM
