well i just reversed and there is an improvement (the screws are from the neck side)
i ques that the qm colors are the same with the dimarzio, because the evo2 in the bridge works and sounds great.
on the other hand as far as the distance conserns, i highered the pup and an improvement achieved.
there is a problem especially at the high e string. so i think that i should higher and flat more the
high strings in order to adjust better the distance of the pup.
