Re: Any advantage to using a single pickup?
Why change a good setup? I like having the option of a neck and bridge pickup set. Noise is not problem if the wiring is good, and your gear is ok. I like lower output pickups anyway, for warm sounds, tone, and less magnetic drain off the strings.
