Pickups & wiring
Anyone else find the Evo Bridge too hot and bass heavy?
Pickups & wiring
10-07-2003, 05:17 AM
zerolight
Posts: 130 - iTrader: (
Well do you?
I'm struggling with mine on my POD XT. In order to get a decent sound from it through the Treadplate (Dual Recto model) I have to turn the bass and mids down very low, turn the presence virtually off, and turn up the treble to about 8 or 9 o'clock.
The neck pickup is just fine, infact if you look at the specs for it on the dimarzio website, its almost identical to a PAF Pro. But the
bridge pickup
is the highest
output pickup
they make, and has loads of bass and mids.
I'm thinking that perhaps a white f-spaced FRED might do the trick. It has about 25% less output, and has less bass and mids.
Your thoughts?
zerolight
Visit zerolight's homepage!
Find all posts by zerolight
10-07-2003, 05:30 AM
Jem7RB MK
Posts: 2,341 - iTrader: (
I have a set of evo's in my MBK and an EVO7 in my RG7,I've really not found any problems with bass,Mids...Gain maybe when clean,but rolling off the vol a little sorts it out with no great loss in volume,I dunno what to suggest,maybe the Evo is just not for your ears,after all were all differant
The Fred is kinda Middy too,not as hot as the Evo by a long shot,Have you considered Breeds?
HTH
Rob
Jem7RB MK
Find all posts by Jem7RB MK
10-07-2003, 09:25 AM
Texter
Posts: 839 - iTrader: (
If you observe DiMarzio's specs you'll see it's a kind of boosted
paf pro
Turn the volume on your guitar down a bit...and Evos aren't specifically bassy, I even find them to lack a bit of bass, which I apply on the amp...
Ofcourse one can never be certain on a modded guitar. My Jems seem perfectly normal to me. Add extra balls is the motto there.
BTW The most powerful DiMarzio is the X2N as far as I know
Texter
Find all posts by Texter
10-07-2003, 10:22 AM
GonWild
Posts: 93 - iTrader: (
hey dude.... maybe its just your XT ?
Im using my DBK with my XT, and it all works fine with the breeds and all.
I have found the Spinal puppet model to be more of
heavy metal
use, while the treadplate is just "chugga chugga"...i dont like it. You should try the puppet, and I'm sure your evos will scream back at ya!
(ps: did you upgrade your xt to 1.04 version?)
GonWild
Find all posts by GonWild
10-07-2003, 10:52 AM
darren wilson
Posts: 4,190 - iTrader: (
Have you tried backing the pickup away from your strings a bit? With a hot pickup, putting it too close to the strings can garble the low end.
darren wilson
10-07-2003, 11:48 AM
zerolight
yeah, i have them wound quite a bit off the strings. i don't know what it is... i have noticed the XT doesnt like
high output pickups
though.
Other than the output and bass on this pickup, the 7VWH is stunning.
zerolight
10-07-2003, 12:00 PM
zerolight
maybe ur right. maybe the treadplate aint great. it had been my fav amp on the XT for a while. i don't know why, but i never liked pupper.
i think pickups above 300mV output seem to distort the virtual pre-amp on the treadplate, and it doesnt seem to like that. i'm sure they probably rock through a real amp.
but looking on the dimarzio site...
your right, they arent bass heavy, just very high 404mV output.
i think its the output more than anything else thats the problem with the pickups and the XT. i'll experiment some more....
certainly, turning presence off, setting bass at 9 o'clock, mids at same, treble at 2:30, and gain around 9 o'clock got closer to a sound I liked.
interestingly I had the same problem with a tonezone in my PRS... though it is bass and mid heavy, but its also very high output... 394mV or there abouts.
zerolight
10-07-2003, 12:36 PM
JemLegacy
Posts: 14 - iTrader: (
here's a suggestion. DON'T TURN OFF THE PRESCENCE.
that'll do the exact opposite of what you want. you're turning off all the clarity. and if you're running into a cab turn off the cab sim on the pod.
JemLegacy
Find all posts by JemLegacy
10-07-2003, 02:15 PM
Ralph khoury
Posts: 451 - iTrader: (
Evos Bassy????
the problem is not with ur evos dude, they have everything but bass! i think its ur poweramp! to what are u connecting ur pod?
Ralph khoury
Visit Ralph khoury's homepage!
Find all posts by Ralph khoury
10-07-2003, 02:18 PM
Ralph khoury
Evos Bassy????
Ralph khoury
10-07-2003, 04:03 PM
zerolight
JemLegacy
not turning off the presence and the evos over power the amp and things break up unpleasantly. the only compromise was to turn down the presence and turn up the treble. without that theres so much gain that the signal gets messed up like putting a
distortion pedal
infront of a recto... it sounds terrible.
turning the presence down tames some of the output from the pickup, i'm not daft, i've been playing guitars for 16 years, and owned many great amps. just sold my rectoverb combo as it happens.
zerolight
10-07-2003, 04:05 PM
zerolight
sacredseventh
Evos Bassy????
very high quality headphones. as i've already said, i now realise its not the evos that are bassy, they're just too high output for the XT. gosh, even 25% less power and their output would still be considered high.
zerolight
10-08-2003, 11:26 AM
JemLegacy
there's something fishy here... I have a jem7vwh and I own a flextone II 2x12 combo no problems there. I suggest something else is the problem. can you post sound clips?
JemLegacy
10-08-2003, 11:54 AM
darren wilson
Doesn't the POD XT have any kind of input attenuator? You should be able to turn down the input level a bit so it doesn't overload. Surely the POD should be able to work with high-output pickups. What would people with EMGs do?
Maybe try taking your guitar and headphones down to a store and try another POD. Maybe there's something wrong with yours that's causing the input section to clip.
darren wilson
10-08-2003, 02:25 PM
Drew
Posts: 4,538 - iTrader: (
How far did you lower the pickups off the strings? I'm probably over 1/4" off, and i'm still getting great results and plenty of gain form my TZ. If they sound too bassy and too hot, those are classic symptoms of pikcups too close to the strings.
Also, have you tried simply lowering the gain on the recto patch?
-D
Drew
Visit Drew's homepage!
Find all posts by Drew
air norton
amp distortion
bridge pickup
bridge pup
darren wilson
distortion pedal
dual recto
heavy metal
high output pickups
jem neck
mesa mark
mesa recto
neck pickup
neck pup
output pickup
paf pro
playing guitar
pod pro
prs mccarty
tone zone
how to find notes per second
Why are 24 fret guitars so hard to find?
how to find scale length
guitar white hardware bridge
how to play heavy metal thru single coil?
12:47 PM
