Audio taper volume pot issue
I just installed a CTS audio taper 500K volume pot. I also put a .001 uF capacitor between input and output terminals. The volume control now has most of its effect in a small portion of the knob (towards the lower volume part). Not sure if the capacitor is effecting that.
Also, the cap seems to leave too much highs in. I tend to like a mellower sound when the volume knob is lowered. Any capacitor values you recommend and also what do you make of the audio taper issue? IU mean I realize that audio taper is non linear but I thought across that nonlinear curve you are supposed to hear a continual change in volume (i.e. the ears process the nonlinear change as linear).
thanks,
brian
