Old 01-17-2003, 06:03 AM
Zli Maxa  is offline
Posts: 8  -  iTrader: (0)
Best Clarity Humbucker?
What Dimarzio neck humbucker haves best clarity in your opinion? I use neck PU mainly for the cleans...
Old 01-17-2003, 06:02 PM
gumby604  is offline
Posts: 76  -  iTrader: (0)
gji
My guess is the PAF classic or the Bluesbucker. They have less output and most likely more clarity. As always, your best bet is to email tech@dimarzio.com.
Old 01-17-2003, 08:58 PM
leishan  is offline
Posts: 110  -  iTrader: (4)
I like Air Nortons in the neck position-I think they have great clarity.
Old 01-17-2003, 10:00 PM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
PAF Pro's are way overrated. I thought mine got slightly muddy on the lower strings. I could never get an eq good enough to not have my bridge be too bright or my neck be too bassy. The Air Nortion is awsome, very tight and clean with lots of harmonics. It's the only neck bucker I buy now.
Old 01-18-2003, 04:34 AM
Zli Maxa  is offline
So you said that AN haves better clarity than Paf pro? I also wonder what PU sounds better splitted... I'm affraid that AN will sound too bassy in my Mahog. guitar
And what about Humbucker from hell? Does anybody tried it?
Old 01-28-2003, 08:56 PM
Drew  is offline
Posts: 4,538  -  iTrader: (4)
Actually, i personally feel basswood has more low end than mahogany- mahogany seems to cut out at the lower mids, but sounds increasingly flat below that point (especially as you roll your volume back), while basswood is definately more rounded in the bottom (and gets that great satch-y wooliness going when you back up the volume a bit in a heavily distorted amp)
Just my two cents, of course...
-Drew
Old 01-29-2003, 07:09 AM
germX  is offline
Posts: 682  -  iTrader: (0)
i don't quite like the PAF Pro in the neck myself. so i looked to the Norton &amp; was correct in discovering that it's a very good neck humbucker for many playing styles.
if you prefer high gain in the neck &amp; still want clarity out of it, try the Super 2. that's what i play in my S540 neck. it has more output than the Norton &amp; may not be what you wanna hear for clean settings.
Old 01-29-2003, 11:09 AM
VOLTAGE  is offline
Posts: 212  -  iTrader: (0)
for clarity,the steve's special is CLEAR and articulate
Old 02-05-2003, 02:39 PM
Gearjunky  is offline
Posts: 169  -  iTrader: (0)
Get a Seymore Duncan, and you'll be fine.
Old 02-05-2003, 02:45 PM
jono  is offline
Posts: 5,003  -  iTrader: (2)
As long as it's not the Invader
Basically anything with a relatively low output but without an excess of bass will provide a clear sound in the neck slot.
I like the PAF Pro for clean and split sounds.
Old 02-06-2003, 07:22 PM
sniperfrommars1  is offline
Posts: 3,302  -  iTrader: (0)
Im gonna stick up for the paf pro. It in its own right is one of the baddest pickups ever. THe air norton is great, but youve got different tones for different styles. I think the paf pro splits better as the coils are better balanced, but the air norton does have more punch but not enough butter for leads.
air norton, air nortons, lower strings, neck humbucker, neck position, paf pro
