Originally Posted by ProFragger
So I was wondering if you guys can tell me the best way to go about this problem. I mean should I contact my local music stores and get a quote from them or are the luthiers the best way to go around it? Whatever the case, where do I find these sources? I mean I tried searching for luthiers in the yellow pages in my area and it found nothing. Also, the only music stores I have near me is a Sam Ash and another local music store. Should I give these guys a call?
If either store has a bulletin board, you might take a look at that and see if there are any ads for guitar technicians / luthiers. I think the odds of someone who works at Sam Ash being able to handle this sort of mod are pretty low.
I think you'll have better luck at the local music store. Also, this may be obvious, but try Google Local. (Though if the Yellow Pages came up with nothing, Google might not help either.)
Also, you can try Jeremy at LGM (see banner above). A lot of people here have had work done by him and are really happy with the results.
One last thing, what would be some of the issues that I might have to deal with in this transition? I mean does the new routing hurt the finish/needs refinishing?
I don't think so. But you should check.
What kind of pickup switches are going to be needed?
I assume you have a five position blade style
pickup switch now. You can just swap it out for a three position switch. (Or keep the five position, if you want a lot of different pickup combos.)
And finally how much extra would it cost me to add a coil tap in the neck?
Do you mean if you have someone doing the wiring for you? I'd guess there's no difference in price
I know I could find a lot of these answers by calling some people, but to avoid being over charged and having some info before calling, I decided to post here to get some knowledge/opinions. Thank you for reading.
P.S: What does it mean by F-spacing and direct mounting and non-direct mounting, and how do these things affect the tone and installation of new pickups?
F-Spacing refers to the spacing of the strings at the bridge on a Fender. (And by extension, Floyd Roses.) Standard spacing is the spacing on a Gibson. Standard spaced pickups are narrower so the pole pieces won't line up properly on a guitar with a Floyd or Fender style bridge. As I understand it, the difference is cosmetic and doesn't affect the sound.
When a pickup is direct mounted, it means that the screws are screwed directly into the body. Otherwise, they're mounted to the pickguard or mounting rings. There are differing opinions on whether or not this affects the tone.
