Re: Breed Pups F spaced or not?
Good choice of pickups, Breed are the best out there.
Almost all modern guitars should be better of with a F-spaced in the bridge (even many LP style guitars). Many guitars, including your Ibanez, will be better of with F-spaced in the neck too.
"F-spaced humbuckers should be used in the bridge position on all guitars with string spacing at the bridge of 2.1" (53 mm) or greater. On these guitars, if the nut width is 1-11/16 (43 mm) or greater, F-spaced pickups can be used in the neck position as well."
It makes a difference to have the right size for the guitar, defiantly worth getting it right.
/Magnus
