Pickups & wiring
Can I use phone cable to extend pickup wires?
Pickups & wiring
02-22-2003, 11:35 AM
kennydoe
Posts: 3,416 - iTrader: (
Hey all
I recently bought an
Air Norton
7, but the lead wire isn't long enough to get thru the route to the switch in my UV.
I have 4 conductor phone wire here that I could use to extend and it'd be nice and neat too, since the wires are already bundled together - I'd just have to add a braided wire (easy enough).
Is phone wire okay?
~Kenny
kennydoe
Visit kennydoe's homepage!
Find all posts by kennydoe
02-22-2003, 01:13 PM
BZ Beetle
Posts: 328 - iTrader: (
I once sucessfully solved that problem (only had about 1" of lead wire on the pup when i bought it) by cutting the wire off an old powersound pickup I had. then once I had the wires soldered together, I put tiny tiny wirenuts on them so they wouldnt short out against each other, then filled the wirenuts with a general purpose super strong glue to make sure they were all secure. still have the pickup with the obnoxiously long wire on it around here somewhere
BZ Beetle
Find all posts by BZ Beetle
02-22-2003, 01:18 PM
kennydoe
OK then.
Assuming i don't have any extra pickups lying around, is phone wire okay?
~K
kennydoe
02-22-2003, 01:22 PM
bammbamm
Posts: 4,134 - iTrader: (
Can you get a foot of Cat 5 cable, that would be better as it is well shielded.
Bamm
bammbamm
Visit bammbamm's homepage!
Find all posts by bammbamm
02-22-2003, 01:24 PM
jemsite
Administrator
Posts: 9,271 - iTrader: (
yes + the ground (unwrapped wire)
cat-5 wire would probably be a bit better, as i believe the wire would be a larger gauge than older phone wire. i'm assuming the phone wire you're looking at is about the same thickness as the pickup wire... g
jemsite
Find all posts by jemsite
02-22-2003, 01:25 PM
BZ Beetle
ok, Yes kenny it will probably work, but i dont know if you'll get any buzz out of it :\ i would love to tell you you wouldnt but you may very well. I say try it. If it doesnt work at all then come back here so none of us bother
hehe
it will work, at least it should, and it wont hurt anything to try. I say go for it, I just cant be sure if youll get alot of buzz or not :\
BZ Beetle
02-22-2003, 03:46 PM
kennydoe
Well, so far so good...it works. The jury is still out on the pickup itself, but at least it works.
I just want to mention, for whatever it's worth, that I didn't snip modular ends off a regular phone cord and start soldering. I'm using the same gague wire they use to run the cables thru the walls, which is definitely thicker that what's used to connect the phone to the wall. It is at least as thick as what Dimarzio uses.
~K
kennydoe
air norton
RG2610 one pickup?
how to put a chrome cover on my dimarzio pickup?
what is the best neck pickup
when to use middle pickup
Evo 2 is the best pickup of all
12:10 PM
