Hi all, thanks again for your input- except 6fingers because he writes silly comments in almost every topic I make- LOL
! I've tried insulating tape and resoldering most joints! I've not yet tried the aluminium foil but I think I could be coming to that next!
Recap
I've resoldered the hots to the right places and the same with the Earth/Ground. Turns out the tech had put the green where the red was to flip which coil was active in 2 and 4 split coil modes. My output is seemingly higher now, but my neck/middle coil (position 2 when looking down at the guitar pickup selector and numbering 1-5 left to right) isn't as nice a clean- I'll find a way of fine tuning the amp eq or something to compensate/rewire the selector (AGAIN xD) in future
I've checked every joint I can with a tester to try to figure out if any are bad joints, all are good.
I've covered the pickup selector joints and most joints with insulating tape.
Verdict:
-STILL THE PROBLEM REMAINS! However, I've found I can get rid of it if i link the volume pot to the tone pot with an unused string I had (this was outside the cavity, actually on the pots where I turn them).
-Is there some sort of "EARTH OVERLOAD"? The guitar is now wired pretty much exactly as the HSH recommendation from dimarzio (difference with pup selector and the Earth of the Volume pot is connected [checked with tester- good connection] with just solder.) I will triple check the wiring though.
Next bit:
Ok, so, if there is an "EARTH OVERLOAD," what should I do now? Should I use the aluminium foil to 'disperse' the current a little? To clarify, the noise is a scratching noise that occurs when I rub my finger ALONG the control knob of the volume pot, or where the control knob should be (I've done both.) I've found that this noise disappears when I create a conductive link to the control knob of the tone pot.
What do you think I should do?
This is getting more and more interesting, keep the advice coming please your really helping me out
Thanks
Regards
Jon
