Pickups & wiring
changing polepieces
Pickups & wiring
11-16-2009, 02:19 PM
j.t..i.
Posts: 129 - iTrader: (
changing polepieces
i ordered a pickup from Dimarzio, and specified to change the
polepieces
to black instead of chrome. Well, they sent a regular chrome one. After contacting them, they are sending me some black polepieces.
Need I just remove the chome ones and replace them with the black ones? Nothing more?
j.t..i.
Find all posts by j.t..i.
11-16-2009, 02:30 PM
djohns74
Posts: 580 - iTrader: (
Re: changing polepieces
I have to believe that they are actually sending new pickups with the correct pole pieces, sending just pole pieces would be a REALLY strange way to handle it as that would not be an easy install.
djohns74
Find all posts by djohns74
11-16-2009, 02:45 PM
j.t..i.
djohns74
No, they are sending polepieces. They say its actually very common to change the polepieces. It's a pickup with allen head polepieces, btw.
02:50 PM
j.t..i.
11-16-2009, 02:53 PM
djohns74
j.t..i.
Not knowing how those types of pole pieces really work, I wouldn't have thought that would be any easier, but I guess I can see it in that case. Regardless, if they're sending pole pieces, then they must be easy to install or they'd never leave it up to a customer to do it.
djohns74
11-16-2009, 02:56 PM
j.t..i.
djohns74
I actually have an old QM2 that came out of my s540, and i removed the polepiece to see what would happen, and it just unscrewed like a normal screw.
I just want everything to be PERFECT in this guitar they're going in.
j.t..i.
11-21-2009, 12:22 AM
LonePhantom
Posts: 5,366 - iTrader: (
Reviews: 98
With humbuckers jt should just be a case of unscrewing the chrome ones, and screwing the black ones in. Pretty simple really.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
11-22-2009, 03:51 PM
steve
Posts: 590 - iTrader: (
Straight up swap-out - they're screws or set-screws.
Just be very sensitive to the threading, as with any screw; make sure they're going in straight, exactly as the ones already in there... it's only a plastic bobbin that it's going into, so the bobbin plastic will be first to give if you cross-thread, or go in crooked.
AND, make sure to do just one at a time - this makes perfect sense to me, and was confirmed by the tech department at DiMarzio.
One out, one in... repeat as needed =]
... and you'll have to do some cleanup of the potting compound that will come squeezing out during this process; it's very much like wax, and just buffs away.
steve
Visit steve's homepage!
Find all posts by steve
11-22-2009, 07:26 PM
scotteggshell
Posts: 73 - iTrader: (
Sharpie...
scotteggshell
Find all posts by scotteggshell
11-24-2009, 01:00 PM
nsabino
Posts: 463 - iTrader: (
scotteggshell
Sharpie...
Sometimes the easiest and most obvious methods just pass you by.....
Regards,
Nelson
nsabino
Find all posts by nsabino
polepieces
how far out can you screw polepieces in a pickup?
changing pickups how to
Changing your own pre-amp tubes?
will changing inlays ruin my guitar?
what does changing pickups do?
older Duncan Jazz - polepieces on one coil are not grounded
horstausmforst
Pickups & wiring
02:14 PM
I need your help changing my name!!!
ChrisReedSmith
Off-topic / Miscellaneous
02:26 PM
polepieces on middle PU on a Jem7
stephan.keuneke
Pickups & wiring
01:50 PM
Replacing The Pickup Screws/Polepieces - Is it possible?
Akhenaten
06:54 AM
04:55 AM
