Old 05-11-2009, 01:01 PM
dark_void86  is offline
Posts: 140  -  iTrader: (0)
Chopper in neck humbucker mounting ring
I was wondering if anyone had taken a guitar with a mounting ring installed humbucker and replaced it with a chopper? But also came up with a decent solution for the huge fat hole that would be left where another coil ought to be?
Sorry if there has already been another thread about this, i couldn't think of the right phrase to search for in the forums......
I also wanted to know if there are many people out there who might have put two single coil sized pickups into a humbucker cavity? E.g. a chopper and a blue velvet into the neck cavity? If they did, how did they do this and what wiring did they end up with?
I hope my query makes sense! This is something i have been thinking about for a while. I just find my neck tones too muddy and my favourite ones tend to be something like Malmsteen, Kiko Louirero, Ron Thal etc.
Old 05-11-2009, 02:36 PM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
Re: Chopper in neck humbucker mounting ring
you could put one of those plastic covers, ala EMG style, over the pickup hole
Old 05-12-2009, 05:28 AM
Hmmmmm, i was considering the idea of glueing a single coil emg style pickup cover to the side of the chopper as a "dummy coil"..............
Still if anyone has done anything like this i would love to hear! Also i was wondering about the idea of feedback, if i do what i just mentioned would it be essential to fill the hole with something else? Just like how guys plug up sound holes and joe satriani fills in the space around his pickups to lessen feedback as much as possible?
Old 05-12-2009, 06:00 AM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
try'd the Humbucker from Hell in the neck ? Also try it flipped around. Great single coil-ish sound.
Also the Evolution neck has the same eq as the HS-3(Yngwie's original neck tone) only louder.
Old 05-12-2009, 07:03 AM
For me when it comes to putting a neck pickup under distortion for sweeping and soloing there hasn't been a humbucker that really does my needs justice. There has to be a "bell" like quality, bounce and articulation that i have only experienced when the signal is captured from the same area/space that a single coil sized pickup does. From what my ears tell me the chopper is my best bet. Even if the HFH or Evo neck pickups sound clearer and more articulate than a normal humbucker in the neck. I am sure I would still want to go for the chopper........
Old 05-13-2009, 04:42 PM
So no one on jemsite has put a dimarzio chopper in as the neck pickup for one of their guitars where a humbucker used to be in a mounting ring?!?
Old 05-15-2009, 02:21 PM
like I already suggested... cover it with a plastic EMG style cover and nobody will know what's under it
you can just make one out of some random plastic and just cut it to fit if you don't want to but anything
Old 05-15-2009, 02:40 PM
moebius  is offline
Posts: 2,043  -  iTrader: (0)
I think you should use a starwars action figure preferably Han Solo and glue him next to you single coil. That way the pickup is your "Solo" pickup.
Old 05-15-2009, 04:26 PM
nsabino  is offline
Posts: 463  -  iTrader: (0)
Hi, try a SD Jazz
Regards,
Nelson
chopper humbucker neck
WTB/Dimarzio Chopper (WHITE) neck pup---**ebow and grovers for sale dakotaplaysguitar Classified Ads: Guitars and Gear 3 04-07-2009 11:59 PM
i need a 540p triple coil neck and pu ring mextremist666 JS (Satriani Model) Ibanez Guitars 0 04-02-2007 04:38 AM
Repairs to neck mounting screw holes mk50h Tech: Setup, Repairs and Mods 4 12-11-2006 02:14 PM
FS: Humbucker set w/ mounting rings, Straplocks (from Proline Series 1660 V) Stygian Classified Ads: Guitars and Gear 14 04-20-2006 04:11 AM
Pickup Mounting - Direct mounting mod? EgbertZombie Pickups & wiring 6 05-03-2002 11:05 AM
