Pickups & wiring
clean up
Pickups & wiring
01-21-2007, 08:45 PM
spkenn5
Posts: 656 - iTrader: (
clean up
hey guys, i'm planning to clean my guitar's electronic as it is kinda dirty, i've been hearing this buzz from changin pickups, volume adjusting etc etc, what do i need to clean them? any tips on what to buy and how to appropriately clean them?
thanks
spkenn5
Find all posts by spkenn5
01-21-2007, 08:50 PM
ibanez2005
Posts: 910 - iTrader: (
Re: clean up
Check your connections for dry joints, check your volume and tone for noisey controls and overall check for bad earths. Nothing some WD-40 anda soldering iron cant sort out.
ibanez2005
Visit ibanez2005's homepage!
Find all posts by ibanez2005
01-22-2007, 12:36 AM
-Rhaab
Posts: 479 - iTrader: (
Re: clean up
if the volume and tone pots crackle and sound scratchy when adjusting the levels i think it would be near impossible to clean, so i would switch those out, they should be about 5-10 dollars
-Rhaab
Find all posts by -Rhaab
01-22-2007, 07:06 AM
Shredder87
Posts: 417 - iTrader: (
Re: clean up
Isopropyl Alcohol (IPA - rubbing alcohol)/Methylated spirits are very useful for this task.
Shredder87
Visit Shredder87's homepage!
Find all posts by Shredder87
01-22-2007, 11:15 AM
spkenn5
Re: clean up
any instruction for replacements or cleaning them?
thanks
spkenn5
01-25-2007, 04:54 AM
Shredder87
Re: clean up
Replacing is easy, parts should be fairly cheap (anyone care to elaborate?). Just a case of taking the pickguard off, removing the stuff from the 'guard and then de-soldering the connections. Putting the replacement stuff in is merely the reverse. Pretty simple if you're handy with a soldering iron. Although you may want wiring diagrams... someone around here should be able to point you to them.
Cleaning, you can take the pots and the p/up switch apart and clean the parts... but A WORD OF WARNING, if you don't know what you're doing then take it to someone who does.
How old is the guitar? You might be better off (less hassle) to just buy new components.
Hope this helps!
Shredder87
01-25-2007, 09:26 AM
spkenn5
Re: clean up
its an 93' RG550
i just sprayed some WD-40 on it, it sounds fairly clean now.
Thanks
btw those mirrored pickguards on *bay, will they fit my 550?
spkenn5
01-25-2007, 09:51 AM
Shredder87
Re: clean up
Cool, glad to hear you've fixed it.
The pickguards on the 'Bay should fit...
Shredder87
Shredder87
mirrored pickguard
wiring diagram
"how to" "clean fretboard"
how to clean a prs guitar
how to clean an oiled maple fretboard
how to clean cosmo hardware
peavey jsx clean vs carvin legacy?
help my clean sound please!!
corganrocks
Pickups & wiring
06:22 AM
Best small clean practice amp - Solid state, good clean tone
Kremlin
Gear and Equipment
12:03 AM
HELP, i need help on fixing my amp!! - My clean channel is w
wolfgang
Gear and Equipment
01:27 PM
Probs with clean channel on Tremoverb - only comes out low v
trapzilla
Gear and Equipment
05:38 AM
POD...clean tone? - How to..
cowcowcow
Gear and Equipment
01:21 PM
02:16 PM
