Pickups & wiring
Coil Split vs Parallel Configuration
Pickups & wiring
02-05-2010, 01:13 PM
Yamadron
Posts: 105 - iTrader: (
Reviews: 3
Hello guys
That question has been revolving into my head and I actually can't get a clear answer about.
Of we said, I have :
Bridge D-A X with coils 1 & 2
Middle Chopper with coils 3 & 4
Neck D-A X with coils 5 & 6
Which would have better cleans having 1 & 2 in
parallel
or coil splitting and having 2 & 3 which I guess in series. Same for the neck configurations as well.
Or it doesn't matter, as both sounds and tones are almost the same.
Another thing, In the Fender Strat guitars, pos 2 and 4, Are the coils in parallel or series to each other ?
Also, any H S H ibanez.. In pos 3, is the middle
single
coil connected in series or parallel ?
Thank you
01:36 PM
Yamadron
Find all posts by Yamadron
02-05-2010, 02:41 PM
djohns74
Posts: 580 - iTrader: (
Re: Coil Split vs Parallel Configuration
I'll start with the questions at the end. In a typical SSS Strat configuration, the blended positions (2 & 4) are in parallel with each other. In fact, any time you blend two pickups, they will generally be in parallel with each other. This is not to say that you couldn't make them in series, but that's not generally how it works.
The question about HSH Ibanezes doesn't make sense. Position 3 would be a single
coil
pickup by itself, it's not in parallel or in series with anything else. Parallel and series describe different ways of combining multiple pickup coils, a single coil is just a single coil.
As for "better cleans", this is a highly subjective question. Personally, I don't use any coils, no matter the configuration, of my bridge
humbucker
for clean tones, so I don't know if I can really answer the specific question very well. In the case of a neck humbucker, I really like the sound of a humbucker wired in parallel for clean sounds, but you can get a very similar effect from the "inside coil + middle single" that Ibanez typically allows on their HSH guitars in position 2 on the 5-way.
djohns74
Find all posts by djohns74
02-05-2010, 03:58 PM
Yamadron
Reviews: 3
Then for the Single pickup in the H S H guitars, the single pickup is parallel to the circuit as It is alone and not combined with another coils.
"In fact, any time you blend two pickups, they will generally be in parallel with each other. This is not to say that you couldn't make them in series, but that's not generally how it works."
If we said that I have a HH guitar, with 3 toggle switch. In the 2nd position, Both neck and bridge HBs are working with each other, Are they connected in parallel or series ? Ibanez says they are connected in series.
Thank you
Yamadron
02-05-2010, 04:03 PM
djohns74
Yamadron
A "normal" 3 way toggle switch results in the individual coils in each pickup being in series with each other (standard full humbucker wiring) and the two pickups being in parallel with each other. Where exactly does Ibanez say otherwise?
djohns74
02-05-2010, 04:24 PM
Yamadron
Reviews: 3
In an Ibanez XPT700
http://www.ibanez.com/ElectricGuitars/model-XPT700
I understand that each humbucker coils are connected in series locally, but they are in parallel globally ? That confuses me too much.
In the switches diagram as you see. When pickups are connected in parallel, they colourize it in yellow not it that reddish colour.
Does the 3 way toggle differs from the 3 way switch if we are using 2 HBs only ?
What i understand that the pickups are connected in parallel with each other whatever combination it is, but the coils of a humbucker could be either connected in parallel or series with respective to each other, Am I right ?
Yamadron
02-05-2010, 04:46 PM
djohns74
Yamadron
In an Ibanez XPT700
Well, the terminology "locally" and "globally" kind of confuses
me
. Referencing your original post, an HH guitar essentially has 4 coils. The bridge has coils 1 and 2, the neck has 3 and 4. With a typical 3-way toggle switch, including those used by Ibanez, the middle position has 1+2 in series, 3+4 in series and the combination of the two set of coils in parallel with each other.
I don't see anything on that page that indicates what the reddish color is supposed to represent. Just because they use red to indicate series connections on some other wiring diagram doesn't mean anything in this picture. Besides which, this isn't a technical diagram, it's just marketing material. The color merely indicates which pickup is active in each switch position.
I don't quite understand the question. There are different kinds of 3 way toggles used for different purposes, for example, DiMarzio makes one, I believe it's the DP1111, that can be used to get John Petrucci's wiring on an HH guitar (full bridge - inner coils - full neck).
Absolutely. You could easily wire a 4-conductor humbucker such that the coils are permanently in parallel with each other, if that's the sound you wanted. Or you can add an extra switch to give you both options, which is more typical.
djohns74
02-05-2010, 05:16 PM
Yamadron
Reviews: 3
I meant by locally, connecting the coils of a humbucker either in series or parallel but globally means connecting coil(s) of a humbucker with another coil(s) of another humbucker or SC
I guess, I was wrong about that. Never mind about that Ibanez stuff.
I just meant that the function of 3 way switch differs from the function of a 3 way toggle. I just figured it about. No problem
yea, that is the project I am willing to do. Having a Push/Pull for Series/Parallel connections.
Thanks a lot for clarifying some concepts for me
Have a nice day
Yamadron
coil
humbucker
parallel
single
split
how to do a herman li coil split
single coil pickup covers how to replace
single coil pickup covers how to remove them
whats a coil tap
how to play heavy metal thru single coil?
Should I Split/Parallel a Fast Track 1???
MityKwin
Pickups & wiring
02:03 PM
Parallel vs. coil split
forest4
Pickups & wiring
10:57 PM
coil split and parallel?
Shredragrammaton
Pickups & wiring
12:06 AM
Whats your favorite AN/TZ combined sound? Out of phase? split coil? parallel?
Rotti
Pickups & wiring
06:55 AM
Coil Tap and Parallel?
Shredcows
Pickups & wiring
01:19 AM
07:01 AM
