Re: converting humbucker to split only one coil
Don't really know why you would want to do this...but here goes:
All you do is solder the black and white wires to ground. Everything else is the same. If you have a switch, all you are doing is toggling whether or not the black and white wires are sent to ground. So for your situation, you'd permanently want to solder the white and black wires to the back of a pot or something else grounded.
