Old 10-10-2007, 10:52 PM
sleepyone  is offline
Posts: 150  -  iTrader: (0)
Custom wiring HELP PLEASE!!!
Hi! Well, I'm planning to do something "special" with the wiring in my mahogany S470 and being a complete electronics NW I need your help. Here's the deal:
Pair of Evo's
Original AS1 sinclo pick up :S (planning to change this soon)
5 position selector
1 volume
1 tone
I want:
Position 1: Neck SERIES
Position 2: Neck PARALLEL
Position 3: AS1 ALONE
Position 4: Inner coils of both humbuckers (ala Petrucci)
Position 5: Bridge SERIES
QUESTIONS:
1: Is it possible to this with a standard 5 position Dimarzio switch, or will I need the multipole one?
2: Volume-->audio pot & Tone-->linear pot?
*IMPORTANT* I NEED A WIRING DIAGRAM TO KNOW HOW TO DO THIS!!!!
I must say also that here in my country I can only get Dimarzio parts, so for the best quality possible I have to buy the Dimarzio products, COULD YOU PLEASE STATE EXACTLY WHAT DIMARZIO COMPONENTS SHOULD I BUY?
ALSO, there's no way of getting the multipole switch here in Argentina, the guitar shops don't bring it here and I can't buy it from the bay...soooo...if the wiring I want isn't possible to achieve with a standard 5 position Dimarzio switch, CAN I GET THIS WIRING WITH IT???
Position 3: Both Humbuckers
This is a wiring like the one in the RGs with 2 humbuckers and 5 position switch (forget about the single coil hehehe)
THANKS SO MUCH IN ADVANCE!!!! I'M REALLY DEPENDING ON YOU PEOPLE TO GET THIS RIGHT!!!!
Old 10-11-2007, 10:09 AM
buddroyce  is offline
Re: Custom wiring HELP PLEASE!!!
You will need a multipole switch to achieve what you want. The closest you can get is probably with a 3-way switch and another switch to coil tap the pickups.
Old 10-12-2007, 09:31 AM
Vim Fuego  is online
Posts: 908  -  iTrader: (2)
Images: 6
Hi I've sorted out a circuit. I've used the Jem wire colours for the pickup leads, but you should be able to work it out (the grey lines correspond to white leads).
(full resolution at http://www.flickr.com/photo_zoom.gne...2133482&size=l)
You'll need a VLX91 switch which I have seen on **** or better still are available from Max at Cottam guitars (see advert at top, that's where I bought mine).
There's really only one switch but on the diagram it's been "folded open" like the Ibanez diagrams.
Jim
'98 Jem7VWH
'91 Jem77BFP with GK-3
RG470FMR
Charvel EVH Art Series (red/white/black)
Burns Brian May
Epiphone G-1275 double neck
Epiphone Sheraton II
Laney VH100R
Boss GT-8
Roland GR-30
Roland VG-88
etc. etc....
Old 10-16-2007, 02:50 PM
Thanks for the help/info!
Old 10-18-2007, 04:10 PM
Agent540  is offline
Posts: 1,073  -  iTrader: (0)
good idea, but why not a serie/split/parallel switch for each PU (Bridge and Neck) ?
You 'll get a lot of combinations and can test the one(s) you prefer
Or replace Vol and tone pots by pots with switch (aaargh don't know how they are called by W Shakespeare !) perhaps push-pull pots ?...
for a parallel/serie combination
Old 10-18-2007, 07:44 PM
I will love to have that switch...but I won't replace vol and tone knobs, I use them A LOT, and no more vol push-pull (I have one installed now in that guitar, it does series-parallel with the neck pickup), I use so much the volume that it always brokes down on me...not enough room also to put one in the tone pot, it's an S...THANKS FOR THE INPUT AND HELP!
charvel evh, charvel evh art, charvel evh art series, coil tap, cottam guitars, double neck, evh art series, guitar shop, inner coils, neck pickup, pole switch, wiring diagram
My Custom RAN (Ibanez S3040PL) Divinewingsoftragedy Other 6-string Guitars (non-Ibanez brand) 5 07-31-2007 08:55 PM
'Custom' Ibanez Shredder stuck in the 80s JEM and Universe Guitars 40 05-16-2007 03:01 PM
blaze custom vs custom 7 (also called NEW 7) ibanez7addict Other 7-string Guitars 13 11-14-2004 11:04 PM
Custom shops/online custom builders? Clydefrog Other 6-string Guitars (non-Ibanez brand) 3 09-22-2004 06:01 PM
Please Help me with a custom wiring diagram (rg7420) GNZ_G Pickups & wiring 2 09-18-2002 10:57 PM
