Pickups & wiring
Did I really need F-spaced pup's with Edge Pro bridge?
Pickups & wiring
Page 2 of 2
05-31-2007, 03:50 PM
Gusfmm
Posts: 280 - iTrader: (
Re: Did I really need F-spaced pup's with Edge Pro bridge?
Yes, regular non F-Spaced pups would have been a bit worse than what you got now. Nuno's pictures are great. As you can see, even F-spaced do not align perfectly. In terms of tone, I have not seen yet anybody factually demonstrating not having a perfect alignment causes any difference in tone.
Regarding the previous question, I think he meant "do not buy" those Duncans specifically. Cause quite frankly, if you're in the process of trying out pups, you must try the Bill Lawrence L-500s and the Dimarzio D-Sonic. At least. Great little widgets. I, myself, lean toward the DSonic.
Gus.
Gusfmm
Find all posts by Gusfmm
05-31-2007, 08:14 PM
neptoess
Posts: 303 - iTrader: (
ive never tryed the D Sonic myself, but Petrucci uses it. The X2N is too gainy for me(no clean at all). The dimebucker is a bad attempt at replicating an L-500XL, which I use exclusively and love. I did mean don't buy the Dimebucker, soooo bright and tinny.
neptoess
Find all posts by neptoess
06-01-2007, 07:07 PM
sleepyone
Posts: 150 - iTrader: (
That's an interesting thing you've done with that sort of foam nuno...I tend to have problems with some
neck pickup
movement in my RG320...I'll try that mod
sleepyone
Visit sleepyone's homepage!
Find all posts by sleepyone
06-01-2007, 07:32 PM
jemplayer55
Posts: 2,627 - iTrader: (
Nuno.... can you post a full frontal of this baby? Nice color/stain! I don't think I've seen one quite that color before.
jemplayer55
Find all posts by jemplayer55
06-04-2007, 09:35 AM
nuno
Posts: 4,725 - iTrader: (
sleepyone
That's an interesting thing you've done with that sort of foam nuno...I tend to have problems with some neck pickup movement in my RG320...I'll try that mod
it's a trick i've learned from Satch's tech Mike Manning. it prevents from squeals and pickups springs noises and buzzes, sort of, at high volumes and lots of gain of course. and yeah, if you pack a lot in there it can also keep your pickup from moving in place. check Manning foaming Joe's guitar
HERE
jemplayer55
et voilà:
other pics
HERE
(english version coming soon, don't mind)
nuno
Visit nuno's homepage!
Find all posts by nuno
06-07-2007, 11:54 AM
Roadstar
Posts: 451 - iTrader: (
I found that dimarzio's F-spaced are not as a exact lne up as duncans tremspaced pups?
my dimarzio F pups all are not exactly lined up dead center like my duncans are!
turns out that a dimarzio F-spaced pup is 51 millimeters and the duncans are 53mm!
from dimarzio,
Our F-spaced pickups measure 2.01" (51 mm) center-to-center from the first polepiece to the sixth. Standard-spaced pickups measure 1.90" (48 mm). Although some players believe that F-spaced pickups are only for the
bridge position
of tremolo bridge guitars, many guitars with fixed bridges (including late 1990s
Gibson Les Pauls
and Epiphone LPs) should have F-spaced pickups in the bridge position. Most tremolo equipped guitars that have a nut width of 1-11/16 (43mm) or more should also use an F-spaced pickup in the neck position. If you’re replacing a bridge-position pickup and you're not sure what your string-spacing is, it's usually better to get an F-spaced model. It is not necessary for the strings to pass exactly over the center of the polepieces for best performance, but it is wise to avoid a situation where the E strings are sitting completely outside of the outer polepieces.
Roadstar
Find all posts by Roadstar
06-18-2007, 12:30 PM
TheJazzTerminator
Posts: 544 - iTrader: (
To the original poster:
I could be wrong, but.... judging by the picture you posted, it sort of looks like your 6th and 5th strings were installed on somewhat of an angle.
If you look at all the
higher strings
, they're going straight over the saddles, which allows them to go straight over the pole pieces. Now, look at the two lowest strings and look at their direction over the saddles; if you're looking down at the guitar, the string is angled more towards the top of the guitar rather than in a straight line.
That could be the reason why the strings are not lining up with the pole pieces, because they're not installed perfectly straight to begin with.
TheJazzTerminator
Find all posts by TheJazzTerminator
06-19-2007, 08:33 PM
70Seven
Posts: 204 - iTrader: (
TheJazzTerminator
If you look at all the higher strings, they're going straight over the saddles, which allows them to go straight over the pole pieces. Now, look at the two lowest strings and look at their direction over the saddles; if you're looking down at the guitar, the string is angled more towards the top of the guitar rather than in a straight line.
It does kinda look like that in the pics, but believe me its not the case. But thanks for bringing it up. Good eye.
70Seven
Find all posts by 70Seven
06-23-2007, 05:53 AM
eg
Posts: 259 - iTrader: (
Just need a confirmation here..
Did I get this right.....
F-spacing only affects the spacing of the pole pieces.
The actual physical dimensions of the pickup housing and mounting tabs should be similar between an f-spaced and non-f-spaced part.
eg
Find all posts by eg
Page 2 of 2
bridge pickup
bridge position
edge pro bridge
equipped guitar
fixed bridge
gibson les paul
gibson les pauls
higher strings
les paul
les pauls
neck pickup
neck position
paf joe
prestige guitar
seymour duncan
spaced pickup
trem guitar
tremolo bridge
how do u measure a bridge
WHAT HUMBUCKER BEST FOR STRAT BRIDGE
how to set up edge zero bridge
TRADE RG 350DX for Edge Pro Bridge or prestige neck!!!
hachimako
03:36 PM
WTB: Ibanez edge or low pro bridge
IanRG7421XL
08:51 PM
IanRG7421XL
07:38 PM
Edge bridge repairs - post & knife edge
jd
Tech: Setup, Repairs and Mods
06:48 PM
New P'ups in my JEM - ...bridge and middle replaced...
kennydoe
11:55 PM
09:43 AM
