Pickups & wiring
Did I really need F-spaced pup's with Edge Pro bridge?
Pickups & wiring
05-30-2007, 08:19 PM
70Seven
Posts: 204 - iTrader: (
I just installed a Paf Joe in the bridge and a Mo Joe in the neck of my RG 2550
prestige guitar
. The guitar has a
Edge Pro bridge
and the poles of the bridge don't line up with the strings, especially the 6th 5th and 4th string. On the neck pickup its more lined up but still a bit off. The 6,5, and 4th string and the bridge pickup are way off. Did I really need F-spaced. When I line up my IBZ Dimarzio the poles line up perfectly, are they F-spaced? What if I got normal/non F-spaced pickup would they have lined up with the strings or would it be even more crooked? I'll try and post pics later.
70Seven
Find all posts by 70Seven
05-30-2007, 08:27 PM
elcid
Posts: 8,718 - iTrader: (
Re: Did I really need F-spaced pup's with Edge Pro bridge?
No. F spaced is just for looks
elcid
Find all posts by elcid
05-30-2007, 08:37 PM
70Seven
elcid
That's what I thought, but it looks wrong !
So there are absolutely no tone difference with F-Spaced?
70Seven
05-30-2007, 08:40 PM
Dee
Posts: 8,514 - iTrader: (
Are you sure you got F-spaced? They should be spot on. Are the poles outside or inside the strings?
Dee
Find all posts by Dee
05-30-2007, 08:47 PM
70Seven
Dee
Yeah I'm sure they are F-spaced, got them brand new, got the Yellow "F-spaced" triangle on the box.
09:04 PM
70Seven
05-30-2007, 09:45 PM
elcid
70Seven
No difference at all. This topic has been covered many times already, if you search the forums for f spaced, you'll probably get a couple hundred hits.
elcid
05-30-2007, 10:40 PM
neptoess
Posts: 303 - iTrader: (
hmm, that is very odd that they didnt line up, if its an f space it should be spot on like the neck
neptoess
Find all posts by neptoess
05-30-2007, 11:10 PM
southpaw_lefty
Posts: 1,140 - iTrader: (
It looks like the neck alignment is off.
The low E is closer to the edge of the fretboard that high E
southpaw_lefty
Find all posts by southpaw_lefty
05-30-2007, 11:27 PM
eg
Posts: 259 - iTrader: (
Good observation.
eg
Find all posts by eg
05-30-2007, 11:36 PM
jaxadam
Classified Watchdog
Posts: 3,042 - iTrader: (
F-spaced doesn't make any difference in sound.
jaxadam
Find all posts by jaxadam
05-31-2007, 12:35 AM
Dee
That's right, but a regular
spaced pickup
in a Floyd or Fender trem guitar usually looks crap. The
bridge pickup
is supposed to be F-Spaced, so something else is wrong. The neck pickup doesn't need to be F-spaced, but the bridge should at least look better. My RG550 is slightly off, but it's not a worry anyway.
Dee
05-31-2007, 07:15 AM
nuno
Posts: 4,725 - iTrader: (
nothing new, actually. DiMarzios aren't lined up to Fender/Floyds very precisely, they're always a bit narrower. Duncans are a bit wider instead. these are some examples of F-Spaced DiMarzios mounted on Edge/Lo-Pro.
F-Spaced bridge / non F-Spaced neck
F-Spaced bridge / F-Spaced neck
not just looks though. being the pole right at the nadir of the its string, it will better "hear" its harmonics and sustain. nothing drastic, though.
70Seven: could you please take a pic right from the exact perpendicular of the top of the guitar? so we can judge the amount of pole/string disalignment. thanks
07:23 AM
nuno
Visit nuno's homepage!
Find all posts by nuno
05-31-2007, 07:46 AM
70Seven
Ok thanks Nuno, I think that answers it. I guess my question was would the gap ben even worse if they were non F-Spaced. And I'm guessing it would. I dont plan on leaving these pickup on for long, I will be trying out a few sets to really see wich pickups give me "my" sound. So far I like the
Paf Joe
but not 100% satisfied with the Mo Joe. So I will first swap them to Paf, neck and Mo Joe bridge, if still not satisfied I will buy a few pair and try some other combination. So I guess I should keep buying F-Spaced for the bridge and neck there is no diferance.
Oh and as southpaw_lefty mentioned, I looked closely at my neck alignment and its not off, it looks like that a bit in the pic but its really not at all, the pickups poles and string show just like in the pic. I guess since the camera was focused on the pickups poles I got the neck/string at a bad angle.
Thanks everyone.
70Seven
05-31-2007, 08:52 AM
neptoess
pickups like Bill Lawrence L-500s, Dimarzio X2N, Dimarzio D-Sonic, and
Seymour Duncan
Dimebuckers(Don't buy these) have blade poles so you don't need to worry about spacing.
neptoess
05-31-2007, 09:28 AM
70Seven
neptoess
pickups like Bill Lawrence L-500s, Dimarzio X2N, Dimarzio D-Sonic, and Seymour Duncan Dimebuckers(Don't buy these)
Why do you say don't buy these? None of these pickups interest me really, maybe the D-Sonic I would like to try it but that's about it.
70Seven
bridge pickup
bridge position
edge pro bridge
equipped guitar
fixed bridge
gibson les paul
gibson les pauls
higher strings
les paul
les pauls
neck pickup
neck position
paf joe
prestige guitar
seymour duncan
spaced pickup
trem guitar
tremolo bridge
how do u measure a bridge
WHAT HUMBUCKER BEST FOR STRAT BRIDGE
how to set up edge zero bridge
TRADE RG 350DX for Edge Pro Bridge or prestige neck!!!
hachimako
03:36 PM
WTB: Ibanez edge or low pro bridge
IanRG7421XL
08:51 PM
IanRG7421XL
07:38 PM
Edge bridge repairs - post & knife edge
jd
Tech: Setup, Repairs and Mods
06:48 PM
New P'ups in my JEM - ...bridge and middle replaced...
kennydoe
11:55 PM
09:57 AM
