Pickups & wiring
Dimarzio BREED's ? somebody help?
Pickups & wiring
09-24-2002, 11:36 AM
VOLTAGE
Posts: 212 - iTrader: (
I wanted to know if the breed set sounds about the same in another ibanez(RG 770) I heard them in the jem and liked them but the 770 is NOT a JEM?
I have a set of
paf pro
's in my rg now and am wondering IF i will like the breed's better in this guitar?
VOLTAGE
Find all posts by VOLTAGE
09-24-2002, 12:05 PM
jono
Posts: 5,003 - iTrader: (
Well the JEM7DBK is pretty much like the RG700 series, with it's wizard neck and
rosewood board
, ok so it's more like an RG750 than a 770 but hey
I personally figure if you liked them inthe JEM you'll like them in the RG770, I don't think most folks would notice that much of a difference, if it's a newer RG770 wth the
direct mounted pickups
you may find a little more bass than the sound of the pickups mounted in the scratchplate of the JEM7DBK
But they should sound pretty much the same.
jono
Find all posts by jono
09-24-2002, 12:33 PM
jono
ibanez otaku
I love the sound of the Breeds (they come in the Jem 7DBK and DNA) especially in the neck position for bubbly shred! I just tracked down the increasingly obscure Yamaha DG100-212 amp (last night) and the Breeds are positively singing through those
Celestion Vintage
30s. Lovely tight and compressed kinda vacuum-packed rhythm in the
bridge position
, super for palm-muted stuff or big prog chords.
I don't own any Tone Zones or Air Nortons, so I can't really compare, but I hear those are great pickups too, so it might not be such a good move to swap one of them out for a Breed...
I've copied this one over from the other thread on the same subject
jono
09-24-2002, 12:40 PM
VOLTAGE
jono
ibanez otaku
neck position
for bubbly shred! I just tracked down the increasingly obscure Yamaha DG100-212 amp (last night) and the Breeds are positively singing through those Celestion Vintage 30s. Lovely tight and compressed kinda vacuum-packed rhythm in the bridge position, super for palm-muted stuff or big prog chords.
Air Nortons
Sorry about the posting prob
I just realized after posting it that the JEM forum would have more luck than the other ibanez one would.
VOLTAGE
09-24-2002, 01:03 PM
sniperfrommars1
Posts: 3,302 - iTrader: (
Actually probably better in tech setup section
Anyhoo the 770 is basically the same component guitar as a jem sans pickguard. The guitar will have miniscule tonal differences involved so just make sure you keep that in mind
sniperfrommars1
Find all posts by sniperfrommars1
09-24-2002, 02:23 PM
mike777
Posts: 656 - iTrader: (
If you've had the opportunity to play a DNA, that would have probably given you the best idea of what to expect. The Breeds were direct mounted on the DNA which also requires less wood to be routed out of the guitar. Both facts have an effect on the sound. I recall that the RG770's (humbuckers) pickups were originally mounted via trim-ring and later (near the end of US availability) they were direct-mounted. Since the standard 770's didn't have pickguards, the body mass would be similar to the DNA-even the non-direct-mounted versions.
Mike 777 Haug
mike777
Find all posts by mike777
09-27-2002, 03:42 PM
microdmitry
Posts: 1,687 - iTrader: (
Breeds in RG3120
It's a totally different guitar (not Jem by any means), but these pickups sound awesome in RG3120. My quest for good pickups was over when I bought these. They're fat, but not muddy. They're powerful, but not overpowering. Their highs are screaming but not harsh. Clean sound of the
neck pickup
is (to my taste) better than the clean sound of paf pro. As any other pickup, though, it might not match with your amp very well. I'm playing my 3120 through Soldano X88R/G Major/custom made low-power poweramp/2x12 cab with G12H30 in it. Sounds GREAT on all 3 channels.
microdmitry
Find all posts by microdmitry
09-28-2002, 01:43 PM
Lonely Raven
Posts: 491 - iTrader: (
micro, have you coil tapped the Breeds at all? I'm looking for something
along the H-H with
coil tap
setup for my JS-6 and a future project guitar.
I'd like something different from the Fred-PAF, but it also has to have a
really good clean coil tapped.
Lonely Raven
Visit Lonely Raven's homepage!
Find all posts by Lonely Raven
air norton
air nortons
bridge position
celestion vintage
coil tap
mounted pickups
neck pickup
neck position
paf pro
rosewood board
tone zone
how to put a chrome cover on my dimarzio pickup?
which way do dimarzio go in
what's hotter EMG 81 or Dimarzio X2N
which dimarzio most like duncan jb
dimarzio ibz?
02:12 AM
