Old 02-20-2009, 05:39 PM
Shredragrammaton  is offline
Posts: 293  -  iTrader: (0)
Red face
Dimarzio coil tap wiring help! Diagram included
Hey guys
Can someone "Connect the dots" for me on this diagram
I need to know what legs of the volume and tone are connected to the base alse, you know how theyre usually bent back a bit?
Volume is a push pull dimarzio pot.
White wires have been shown in blue !
My soldering iron heats ...
Old 02-20-2009, 05:40 PM
Re: Dimarzio coil tap wiring help! Diagram included
Also , there are 3 legs on the jack socket, 1 is smaller and the other 2 are the same height . I had emgs in before so i understand it is a stereo jack , and to wire up the dimarzios means only using 2 pins?
Lost!
Old 02-20-2009, 05:58 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
http://www.guitarworkshop-uk.com/pag...H%20Wiring.pdf
dont forget to turn the neck pickup upside down, I hope you got a true velvet S (DP175S)
Old 02-20-2009, 06:00 PM
Jaden  is offline
Lost!
long = ground
medium = signal
Old 02-20-2009, 06:57 PM
Angry
Hey bro !
That diagram doesnt have the push pull dimarzio volume pot i have , like with a box on it and an extra 6 pins! Im pretty lost !
Yup its a true velvet S
Pity i cant hear the damn things !
Old 02-20-2009, 07:01 PM
infact im not sure if its a true velvet S , or just a normal one! it has a black and a white wire . The diagram i drew is indenticle , 5 way switch , 1 500k tone , 1 push pull volume pot - i left out the capacitor by accident.
Do you reckon you could join the lines for me in colour on ms paint and upload it here?
I just tipped every wire with solder, so im ready to go , just no clue what to do !
What legs of which pots get bent back to the base?
Which pegs of the jack do i use?
And on the push pull , it has the box on the base so i cant solder wires to the base as usual - do i solder to the side of the unit or the base of the actual 6 pin box ?
Old 02-20-2009, 09:30 PM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
forgive me for the "spider-web" diagram but this is how I have my 760 wired for coil tap :P hopefully this makes sense!
Reg
Old 02-21-2009, 01:35 AM
jallen  is offline
Posts: 631  -  iTrader: (14)
Have you emailed Dimarzio? In my experience, they are incredible at getting back to you with diagrams of what you need. I once needed a diagram for a flying V with two Virtual PAF's with a push/pull on the tone for coil split. Within the day I had my printable diagram in hand. They are great- use them!
Old 02-21-2009, 06:31 PM
Gah !
Spent 8 hours in all with numerous attempts and no luck!
So i had to admit defeat and head to the guitar shop and let a friend there do it for me!
Now ive no guitar atall and my amps just sitting looking at me !
Wiring Diagram for coil tap on jem? mooro JEM and Universe Guitars 1 04-26-2008 02:12 AM
Need wiring diagram for Dimarzio pickups evolvedmb Pickups & wiring 4 04-05-2005 02:18 AM
Dimarzio Pickup Question/Wiring diagram. moonstar Pickups & wiring 9 07-11-2002 06:49 PM
