Old 06-26-2009, 02:58 AM
Jakem  is offline
Posts: 162  -  iTrader: (0)
Dimarzio D-Sonic wiring/installation help needed
Hi there,
I'm about to change the bridge pup (PAF Pro) on my Ibanez RGT3020FM to a D-Sonic with the bar facing towards the neck and I have a couple of questions:
-do I need to do any changes for the wiring or can I just solder D-Sonic's wires in the same way as the PAF Pro's wires were?
-I think I heard somewhere that if I install the D-Sonic with the bar facing towards the neck, I need to reverse the neck pickup direction. Is it true or is it just for some different wiring scheme than this?
Here's RGT's wiring diagram:
Thanks!
-Jaakko
Old 06-26-2009, 04:34 AM
teokiatuan  is offline
Posts: 425  -  iTrader: (0)
Re: Dimarzio D-Sonic wiring/installation help needed
with reverse direction or not, the wires still stay connected to the same spots
Old 06-26-2009, 05:20 AM
mi2tom  is offline
Posts: 7,522  -  iTrader: (4)
Yup, it's the installation direction only, the wiring still remains the same.
Old 06-26-2009, 04:17 PM
Jakem  is offline
Thanks for your help!
-Jaakko
Old 06-26-2009, 04:36 PM
buddroyce  is offline
While you COULD wire it up like a PAF Pro, I believe the pickup was initially oriented with the bar facing the bridge so flipping the pickup around so that the bar faces the neck with result in both coils facing the bridge in position 2 (one up from the bridge humbucker). If you want to maintain the wiring so it's got the two inner coils in position two I believe you want to flip the red and green wires around on the D-Sonic.
Old 06-26-2009, 05:07 PM
Typhonian  is offline
Posts: 23  -  iTrader: (0)
Correct. It sounds great in position 2, in case you want to replace the wires and flip the pickup around.
Old 06-26-2009, 05:11 PM
Jakem  is offline
Interesting. Do I have to do any changes for the neck PAF Pro's wiring or direction if I want the inner coils of both pups to be on at position 2? How about hum cancellation?
-Jaakko
Old 06-29-2009, 05:11 PM
Jakem  is offline
-Jaakko
Does anyone know the answer for this? Thanks!
Old 06-29-2009, 11:55 PM
You just need to swap the wires around on the D-Sonic. You wouldn't need to screw with the Paf Pro wiring at all.
Old 06-30-2009, 01:03 AM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
switch the red and green wires on the D-sonic
Old 06-30-2009, 04:58 PM
Jakem  is offline
Thanks for the answers!
-Jaakko
d-sonic, pickup installation
Dimarzio D Sonic Vs Dimarzio Super Distortion artension Pickups & wiring 2 01-24-2009 06:44 PM
EMG wiring installation help btbamman Pickups & wiring 4 08-23-2008 12:47 AM
Help with First time wiring dimarzio needed Sonicity Pickups & wiring 1 03-25-2006 10:59 PM
Dimarzio Paf 7 installation - which way is right??? ANOVA Tech: Setup, Repairs and Mods 3 09-05-2001 07:46 PM
DiMarzio Straplock installation - In what order do I put thi Anonymous Tech: Setup, Repairs and Mods 5 07-05-2001 10:20 AM
