I just received a used
Dimarzio DP165 Breed neck pickup in the mail. First thing I did was measure the
DC resistance across each coil separately to test for continuity (as you do).
I measured just under 5K ohm for each coil separately, for a total series measurement of 9.78K ohms. The Dimarzio published spec is 10.14K ohms for the DP165. Within 4%, but more of a difference than I would have expected. These aren't hand wound 1950s pickups...
The back plate is stamped Dimarzio DP165, and there aren't any obvious signs of a rewind or anything like that.
Anyone actually bother to measure the DC resistance on their Dimarzio pickups and compare to the published number? How close did you get?
FWIW, I've installed the pickup and it sounds fine and as expected. So not a major issue obviously, but a minor mystery – it’s got me curious. Are differences in actual readings versus spec often of this magnitude for this manufacturer?
I’ve got a new DP166 and ISCV2 coming in the mail soon, hopefully, so it will be interesting to measure those and compare to the published specs.
BTW, you easily measure the DC resistance of an installed pickup without taking the guitar apart – just switch the pickup selection to that pickup, plug in a guitar lead, and measure the resistance across the plug tip and shield of the lead. Handy trick – even if obvious in hindsight.
