Re: Dimarzio Evolution in Ibanez RG1570
No worries about string pull, at the bridge location there is far less movement in the string, so strong magnets or close placement doesn't have anywhere near the same effect as with a neck or middle pickup. If you don't like the sound of it though, then you have to route the cavity a little deeper. Or you could shim the neck and raise the bridge which is a lousy idea. You say "as far as it will go", but does that include foam underneath? Is there anything blocking it from underneath? Basically find out if the ears are touching the base on each side. If not, then you could get away with just routing/dremeling a little cable relief, or drill tiny shallow holes where the four coil mount screws are under the pickup. If the ears are in direct contact though, then you have to route that part deeper.
