Old 10-28-2007, 03:10 AM
ax1  is offline
Posts: 26  -  iTrader: (0)
Exclamation
dimarzio help
i have just installed a d activator bridge. my good friend soldered the black and white wire to the 3rd pole and the red to the 8th pole. this is because the old pickup wires were already soldered there. is this the right wiring?
thanx
Old 10-28-2007, 03:28 AM
ax1  is offline
Re: dimarzio help
my bad. soz. i put the black and white to the 6th and the red to the 1st
-Rhaab  is offline
Posts: 479  -  iTrader: (0)
Re: dimarzio help
try it out, it sounds like its all where it should be.
Old 10-28-2007, 05:17 AM
ax1  is offline
Re: dimarzio help
my switch in pos 2 is louder than pos 1
Old 10-28-2007, 07:12 AM
Cataclysm  is offline
Posts: 5  -  iTrader: (0)
Re: dimarzio help
I'm pretty sure you got parallel wiring instead of series cos you bunched those wires up, which might be the problem. Well at least it doesn't sound like a nasal congestion anymore...
Old 10-28-2007, 02:01 PM
buddroyce  is offline
Re: dimarzio help
Depends on the switch. Try taking off the black and white wires off the "3rd pole" to see how it sounds.
Old 10-29-2007, 06:57 AM
ax1  is offline
Re: dimarzio help
I have a cortek switch btw and is the INF3 meant to be louder than the d activator. i have to lower the INF3 very low to get an even volume. Is there any way of measuring the output of the d activator.
kind regards
ax
Old 10-29-2007, 08:17 AM
toshiro  is offline
Posts: 1,812  -  iTrader: (11)
Re: dimarzio help
What model Ibanez is this? When you look at the switch, there should be a wire from one of the poles to ground(the back of a pot), and the black and white wires should be on that "side" of the switch. Also, he did wire the green and bare to the back of the pot, correct?
Do you prefer 'brand name' DiMarzios or DiMarzio/ IBZ TheJazzTerminator Polls 5 08-18-2006 06:16 PM
FS: Dimarzio Pickups and Cliplocks gpenguins Classified Ads: Guitars and Gear 12 06-02-2006 10:14 AM
...in praise of DiMarzio ibanez otaku Gear and Equipment 20 02-14-2005 08:07 PM
Parker Fly owners, pickup info. bammbamm Pickups & wiring 6 02-11-2003 10:35 AM
