DiMarzio Nuno pickup - Jemsite
Old 11-28-2007, 12:01 PM
jono  is offline
Posts: 6,484  -  iTrader: (2)
OK false advertising I admit - sorry!
But now that you're here I'd like your advice on what pickup will help me get close to Nuno's bridge pickup sound.
I knwo you'll all say a Bill Lawrence, but there are 2 problems with those pickups,
1) I don't know which Bill Lawrence is Bill Lawrence and which one or which model Nuno uses.
and
2) It's highly probably I'll want a red, purple or blue pickup at this rate to go in an RG770DX
Thanks guys
Old 11-28-2007, 12:11 PM
screamndemon69  is offline
Posts: 5,711  -  iTrader: (13)
Re: DiMarzio Nuno pickup
Bill and Becky are the orginal Lawrences and they still make pups. Those are/were the original pups in Nuno's guitars. I highly doubt they do colored versions but you can always do a search to find their # or email address (if someone else here doesn't post a link for you).
If you can find the specs on the original BL pup, match the specs to something from Dimarzio or Seymour so you can get the desired color. Just my 2 cents.
Old 11-28-2007, 12:35 PM
rgr  is online
Posts: 1,836  -  iTrader: (9)
Yep, the B&B ones are the "real" ones, but Washburn is putting the BLUSA ones in the new guitars (and has been for a while). The one in Nuno's main N4 is a B&B, you can tell in some closeup pictures. I have a N6 that came with the BLUSA pickup in it, I put in a B&B L500-XL and like it better, but they are similar (Bill designed the originals and both companies are pretty much sticking to the original recipe, but the B&B ones seem to be made better).
As far as a DiMarzio, tough call, nobody really makes a pickup that is very similar. The BLs are very balanced without an excess of mids, highs, or lows, being that they are balanced, they do sound quite clear and a little bright. I would probably suggest a Steve's Special to get the clarity, highs, and openness of the BLs. My next choice would probably be a regular Norton, probably not as hot, but it is a very open and clear sounding pickup.
Old 11-29-2007, 11:13 AM
If I remember right, I think there are 250k pots in the N series to help fight the brightness rgr referred to.
I had a new N6 for almost a year and the BLUSA sounded great. My brother now owns it and he also has an old Roadstar with an original in it that has a very smooth sound to it.
Old 11-29-2007, 11:21 AM
rty13ibz98  is offline
Posts: 1,982  -  iTrader: (34)
i have an n2 that has an l-500 in it...sounds like nothing else. very bright pickup. kinda thin because the bass is lacking, but sounds pretty good. has that nuno sound. kinda makes me wish i would have kept my old mp-1 for it. i have owned/played a ton of duncans and dimarzios and nothing that i have used from either company sounds like the lawrence.
rich
Old 11-29-2007, 12:25 PM
mfergel  is offline
Posts: 667  -  iTrader: (22)
Yeah, I had an N4. 2002 I think. Way too bright for me. I've got an N3 now with a Breed in the bridge and it sounds awesome.
Old 11-29-2007, 12:53 PM
rgr  is online
I'm pretty sure the pots in my N6 are 500Ks, no way to really check it without pulling the pickguard though.
Old 11-29-2007, 12:56 PM
I'm not 100% sure either if they are 500k or 250k. It seemed like they are 250k since the overall output of my (ex) N6 was lower than my other guitars with 500k pots.
Old 11-29-2007, 02:13 PM
my n2 has a 500k push/pull. now has a OFR and duncan 59, too(wish it were a 4-conductor 59, tho)
rich
Old 12-08-2007, 04:15 PM
linthat22  is offline
Posts: 229  -  iTrader: (0)
I remember playing a Nuno model back in the day (94-ish) and the BL pup in the bridge sounded really bad. On the other hand I have the same BL pup installed in one of my guitars and it sounds great.
I think like most guitars and pups, your mileage may vary depending on what your ears like. Hope that helps
Old 12-09-2007, 11:03 AM
What amps was he using at the time? I saw him back then too but I don't remember what he had onstage.
Old 12-09-2007, 03:32 PM
RSVampire  is offline
Posts: 1,813  -  iTrader: (6)
you could always get a Dimebucker from Seymour Duncan and order it in different colors.
Or get an X2N from Dimarzio and order them in different colors.
they aren't the exact pickup Nuno uses but they are close and they give you the colors options yo wanted.
Old 12-10-2007, 11:25 AM
rgr  is online
The Dimebucker only comes in black, no colors. It will be similar to a BL. Haven't tried an X2N.
bridge pickup , seymour duncan
Dimarzio pickup wiring Van-Hannam Tech: Setup, Repairs and Mods 24 04-27-2011 10:44 PM
WTB: GREEN Dimarzio Blaze 7 SINGLE COIL pickup. 7Strings Classified Ads: Guitars and Gear 1 07-07-2007 02:39 PM
WTB: GREEN Dimarzio D Activator 7 NECK Pickup 7Strings Classified Ads: Guitars and Gear 0 07-04-2007 11:44 AM
Which neck pickup match for DiMarzio Super Distortion? kent Pickups & wiring 5 09-25-2006 12:19 PM
Did Ibanez cheap out with their stock pickups? [no, they're DiMarzio made for Ibanez] TheJazzTerminator J-Custom, USA Custom & Prestige Ibanez Guitars 224 08-18-2006 07:48 PM
Powered by
