Go Back   Jemsite > Toolbox: Setup, Repairs and Mods > Pickups & wiring
Old 10-19-2009, 01:13 PM
valcian valcian is offline
Posts: 15  -  iTrader: (0)
Dimarzio pot question
So, I'm a bit confused, basically the volume pot in my old EDR-170 is crackling and cutting out, so it needs a replacement, I'm thinking a dimarzio (I know it's a 500k pot, and apparently dimarzios are high quality, so it makes sense) does anyone know if the Dimarzio pots are the same size as the Ibanez 3VR1C500B pots used on the 2003 edr-170? (I'm guessing they're used on other guitars too).
Thanks,
Valcian
Old 10-19-2009, 01:23 PM
Jaden's Avatar
Jaden Jaden is offline
Posts: 2,327  -  iTrader: (7)
Re: Dimarzio pot question
dimarzio pots are bigger than the mini stuff fitted OEM, the shaft is a larger diameter too.
so you have to drill the pickguard to 10mm - they are very good quality, I sell loads.
Old 10-19-2009, 01:47 PM
nsabino nsabino is offline
Posts: 213  -  iTrader: (0)
Thanks,
Valcian
You could also make a role with sandpaper and lightly sand until the orifice allows the pots shaft to fit. It's easier and less prone to a screw up than drilling. Your call, that's how I did it on my Ibby when I changed pots.
Regards,
Nelson
Old 10-19-2009, 02:04 PM
Thanks, the EDR doesn't have a pickguard, it's rear routed, with bevels for the knobs, true it also has a plastic body, so idk if that'll make it easier or harder to expand the holes.
Old 10-19-2009, 04:01 PM
My RG770 is also rear routed, I used the technique I mentioned, sanding round and round and checking for fit, it's basswood but the same principle applies.
Regards,
Nelson
Old 10-20-2009, 01:59 PM
moonlight moonlight is offline
Posts: 115  -  iTrader: (0)
Not sure what knobs you have but when I installed Dimarzio pots in a couple of RG520's the course spline Ibanez knobs wouln't fit the fine spline on the Dimarzio pot so I had to change the knobs and file out the holes in the body. All said and done...it was worth the change.
Old 10-20-2009, 05:56 PM
Yeah I changed the knobs and went with CTS pots, bigger sound all round I don't know how DiMarzios are but the size is the same.
Regards,
Nelson
Fishman VT Powerbridge
As low as $169
at 7 sellers
Graph Tech Slotted Trem-Nut with 1/4" String Spacing
As low as $9
at 6 sellers
Members with more than 50 posts don't see this bar
Seymour Duncan Everything Axe Single Coil Set White
As low as $206
at 3 sellers
Bogner Alchemist Series 212 40W 2x12 Tube Guitar Combo Amp Black
As low as $1199
at 10 sellers
Taylor 900 Series 916ce Grand Symphony Cutaway Acoustic-Electric Guitar Natural
As low as $3199
at 5 sellers
Electro-Harmonix XO Q-Tron Envelope Filter Guitar Effects Pedal
As low as $133
at 8 sellers
Alfred The New Best of Pantera for Guitar Tab Songbook
As low as $7
at 4 sellers
Schecter BlackJack ATX C-1 FR Electric Guitar Aged White
As low as $899
at 3 sellers
Korg D3200 Multitrack Recorder
As low as $750
at 15 sellers
Hal Leonard Love Songs Fingerstyle Guitar Tab Songbook
As low as $7
at 9 sellers
BC Rich Exotic Classic Mockingbird Electric Guitar Spalted Maple
As low as $588
at 4 sellers
Martin M540 Phosphor Bronze Light Acoustic Guitar Strings
As low as $4
at 7 sellers
Gretsch Guitars G6120SSLVO Brian Setzer Signature Nashville Guitar Light Vintage
As low as $3100
at 3 sellers
D'Addario PL011-5 Strings
As low as $2
at 3 sellers
dimarzio, edr-170, pentiometer, pot
close
Sign up for free and join one of the largest communities of Jem guitar lovers!
Our members will be glad to help you with anything you need!
Join over 30,000 JemSite members!
Email
Email Confirm Email
Username
Password Confirm Password
I agree to the website rules
