Old 08-06-2009, 11:10 PM
ShredGH  is offline
Posts: 109  -  iTrader: (0)
Question
Dimarzio Single Coil Suggestion
Hey there I have an Ibanez rg350mye that I'm putting a dimarzio evolution bridge and neck in, what dimarzio single coil would go well with the evolutions?
Thankss
Old 08-06-2009, 11:12 PM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
Re: Dimarzio Single Coil Suggestion
Dimarzio ISCV2=evo single
Old 08-07-2009, 11:09 AM
ShredGH  is offline
Thanks LuredMaul. Yeah I heard about it and has anybody tried it? is it good? Sorry I'm kinda new to pickups.
Old 08-07-2009, 03:20 PM
I like it......you won't get much info from Dimarzio other than it's made specifically to sit between Evo's an it's 160mv.
It makes nice split tones. does the job well.
Old 08-07-2009, 03:23 PM
buddroyce  is offline
Depends on what kinda of sound you want, but the ISCV2 (Evo single) balances very well with both the Evolution set and the Evo2 set.
Old 08-07-2009, 08:32 PM
nickcoumbe  is offline
Posts: 2,417  -  iTrader: (0)
Reviews: 34
Absolutely agree.
Actually the Jem and evo singles are all good. I also thought the S1 wasn't too bad as well.
Old 08-08-2009, 07:40 AM
Algiman  is offline
Posts: 2,553  -  iTrader: (14)
Yep, if you are looking for something to balance with split evos, then the ISCV is the way to go. I don't particularly rate it as a single coil to use on its own, but for that application it is perfect.
Old 08-08-2009, 10:27 AM
mike570  is offline
Posts: 2,222  -  iTrader: (0)
Reviews: 18
HS-3.
Old 08-09-2009, 10:28 PM
rlavergne09  is offline
Posts: 7  -  iTrader: (0)
I am in the same situation.. I am looking at either the set of evolutions or putting the evo 2 in bridge and evolution in neck. I am leaning toward the evo 2 in bridge and evolution in neck because I've heard it's not as shrill and thin as both evolutions. however, i still don't know what middle pup i should go with. i suppose i cant go wrong with the ISCV2, but i didnt know if anybody suggests something else, like the Area '61 or something. I will be putting these in an rg350 with basswood body if that helps at all.
Thanks in advance guys
350mye, dimarzio, pickup, rg350mye
WTB pink dimarzio single coil kpollock9 Classified Ads: Guitars and Gear 1 11-10-2008 12:25 AM
Dimarzio Single Coil Pickups! BirdHouse Pickups & wiring 9 06-02-2008 08:48 AM
WTB DiMarzio single coil cover(s) Ayrton Classified Ads: Guitars and Gear 0 09-16-2007 11:38 PM
WTB Dimarzio single coil cover Davey Classified Ads: Guitars and Gear 0 11-17-2006 08:14 PM
WTB pink dimarzio single coil magkid45 Classified Ads: Ibanez JEM/UV Guitars 1 12-30-2005 12:47 PM
