Here's my problem. I've got an old LP that I want to wire a certain way, but not knowing a lot about it, I can't do it without a diagram. I can't find one anywhere on the net. Two umbuckers, four pots. All pots are push/push switches, and there are two additional mini toggles. What I want to do is:
bridge vol pot splits
bridge pup to single coil (up single, down humb)
neck vol pot splits neck pup to sc (up sc, down hb)
bridge tone switches bpup from series to parallel (down is "normal", and I don't know if that's s or p)
neck tone does same for neck pup (ditto)
mini toggle 1 switches both pups from seried to para
mini toggle 2 switches both pups in or out of phase
Can this be done? How? Thanks in advance for any help!
