Pickups & wiring
EMG 89/85 wiring with push-pull volume pot
Pickups & wiring
11-22-2008, 07:38 AM
Jacob K
Posts: 183 - iTrader: (
Hi all,
I found a good deal on an
EMG 89
and an EMG 85 ($90) which I plan to put in neck/bridge respectively.
The EMG 89 is designed to work with a push/pull tone pot.
I am going to install them in my new 540P-II. However, it does NOT have a tone knob, and I don't want one either!
Does anyone have some wirering suggestions for this? I have an idea that it shouldn't be that hard.
Thanks in advance.
Jacob K
Find all posts by Jacob K
11-22-2008, 11:12 AM
markyperfection
Posts: 233 - iTrader: (
Re: EMG 89/85 wiring with push-pull volume pot
Wire the
push-pull
as your master volume and use the included tone pot as a fishing lure!
With your 89, the two pots it comes with will be wired together with a green capacitor and a piece of black wire. Unsolder both of those from the push-pull pot.
At this point, the only wires that will be connected to the push-pull will be a thin silver wire (ground) that grounds lug 3 to the case of the switch portion and another with a clear sleeve over it (output) that connects lug 2 to one of the common poles of the switch. Leave (ground) where it is and completely remove (output) from the pot. Put a new wire where you just disconnected (output) from on the switch and run it to the neck-position pole on your pickup selector.
After that, everything is the same as a standard
wiring
setup: Connect your ground to lug 3 on the pot, your main out from the pickup selector switch to lug 2, and connect the white wire from the output jack to lug 1.
I hope that's clear enough; I have a tendency to ramble a bit. Feel free to PM me if you have any questions or need clarification.
markyperfection
Visit markyperfection's homepage!
Find all posts by markyperfection
11-23-2008, 01:22 PM
Jacob K
Thanks for that, marky, I'll see if I can make some sense of that when the pickups actually arrive. I might send you a PM, thanks for offering me that
Jacob.
Jacob K
11-24-2008, 10:00 AM
7 Dying Trees
Posts: 1,708 - iTrader: (
http://www.geocities.jp/dgb_studio/EMG_89_e.htm
Get a 5 way 4 plate switch (the dimarzio super switch) and you'll be able to wire it up in a multitude of ways.
I've used that webpage to wire up a friends guitar with an 81/89 combo in it, if I am correct it has:
B / B + N (S) / B + N / N (S) / N
so 5 positions, 5 wirings, no push pull required.
7 Dying Trees
Find all posts by 7 Dying Trees
11-24-2008, 10:50 AM
Jacob K
Whoa, that's awesome! Exactly what I didn't know I was looking for!
I'm definetly gonna look into that, which of these wirings did you use exactly?
Jacob K
11-24-2008, 01:48 PM
7 Dying Trees
Jacob K
I can't quite remember which one it is, as it wasn't for my guitar!
But yeah, it's very usefull, and means you can use a 5 way, as otherwise you are stuck with using both a push pull and a 3 way which is a bit retarded.
Anyway, I'd just pick one you like the look of and wire it!
Glad to have been of help
7 Dying Trees
11-24-2008, 03:20 PM
Jacob K
Heh, I'll do that
Just out of interest, got any schematics for the simplest possible wiring for a single EMG pickup without any controls, straight to the output jack? Is it just the pickup in serial with the battery?
Jacob K
11-27-2008, 08:14 PM
7 Dying Trees
Kind of, the battery goes to the pickup with the output jack acting as a way to stop battery power (ie, no jack, no circuit, no battery draining).
For the rest, you just have an earth wire to the pickup and the live. it is simple, but always on just sounds like a recipe for disaster unless you have a volume pedal
7 Dying Trees
emg 89
push-pull
wiring
stereo output guitar mono how to electric wiring
how to pinky pull up
push pull pots how they work
Ibanez Guitar wiring?
magnetic push button switches how they work
Need Help, Wiring with a push/pull & Super Switch
Koldgrin
Pickups & wiring
05:29 PM
push pull pot wiring help
JohnnyRG1527
Tech: Setup, Repairs and Mods
03:06 PM
wiring using push pull switch
Jeff - CRO
Pickups & wiring
04:28 PM
Using volume/mini-toggle push/pull pot as a pickup switcher?
guitarkatana
Pickups & wiring
11:57 PM
Wiring EMG with push/pull pot - How would I do this?
ChrisReedSmith
Gear and Equipment
08:40 AM
06:19 AM
