Old 03-10-2003, 03:47 PM
Break Zero  is offline
Posts: 99  -  iTrader: (0)
EMG Afterburner question
Alright, I have an ESP F200, which has two EMG HZ's equipped, and has the Afterburner feature (for those of you who don't know what that is, you pull a switch up and you get a 20dB Variable Gain Boost). I was thinking of replacing the pick ups with an EMG 81 and a 85 or 60, but I'm wondering if the Afterburner would still work with the different pickups? ESP's Grynch model also has an Afterburner and is equipped with an 81 and a 60, so I'm thinking yes, but I just want to make sure...
Old 03-10-2003, 04:07 PM
BrianH  is offline
Posts: 599  -  iTrader: (0)
yes it should work fine
Old 03-11-2003, 12:34 PM
Jammy  is offline
Posts: 868  -  iTrader: (1)
I have an afterburner question also...so i thought i mayswell post it here instead of starting a new thred (hope you dont mind Break Zero ) I Have been looking to get volume boost for solos for a while now, and ive tried overdrive pedals, and a few other things reccomended to me by my local guitar shop, but nothing seems to work . I was condsidering one of these afterburner gadgets, but not knowing anyone with one, or being able to try one i am reluctant to part with my dosh .
Do any of you guys have one? if so is the volume boost you get noticable.
Also, could my whole hunt for this "boost" be in vain, because, infact, the overall volume of my setup is infact detirmined my my master volume control on my amp and therefore a volume boost is impossible without actually turning it up?
thanks
-better shred than dead- ANDY
Old 03-11-2003, 08:37 PM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
My friend has an F-200 as well with the HZ and Afterburner thing. The afterburner doesn't work well when you're using distortion as you'll end up getting more feedback. I'm sure it'll work as it was designed when you plug it in to a clean channel. Personally, I thought the HZ on my friend's guitar sounded pretty close to an 81.
I also installed an EMG Preamp booster switch a few years back and it's works the same as an Afterburner. The Afterburner is activated by pushing the tone knob up while the Preamp booster is activated by flipping a switch (duh).
Reg
Old 03-12-2003, 01:00 PM
vaijem777  is offline
Posts: 2,980  -  iTrader: (17)
Jammy- if you're just looking for a clean boost, you might try a Fulltone FatBoost. It offers 30dB of CLEAN boost without any change to your EQ at all.
The Robert Keeley Time Machine Boost offers 23dB of boost, but is quite a bit pricier.
guitar shop, local guitar shop, overdrive pedal
