Hey,
I have a wiring problem with my Emg-equipped guitar...I think. It has a 60 in the neck position and a 81 at the bridge, one volume and a 3-way switch. When it is plugged in and the volume poti is turned up, there's a buzzing sound like when you touch the tip of the unplugged guitar cable, only much quieter.
It doesn't go away when you touch the strings/bridge, but it gets much better when you touch the pickups/jackplate/switch. So I thought it was a grounding issue and brought the guitar to a technician, who renewed the whole wiring inside the guitar (or at least that's what he said...). Problem still exists.
Then I thought, maybe it's the pickups themselves which are somehow damaged. I changed them for another pair of Emgs - same problem.
So it shouldn't be a wiring issue and it's definitely not the pickups. Whats going on here
I'd be really thankful for ANY ideas!
Best regards,
Alex
