Pickups & wiring
EMG wiring problem
Pickups & wiring
12-29-2012, 02:52 PM
marcoma
Posts: 8 - iTrader: (
EMG wiring problem
I have 2
EMG
89 pickups and an
SLV
pickup, one volume and one tone.
I'm having trouble working out how to connect then together with just one volume control (push/pull) to control all three pickup volumes.
I cant seem to find a diagram that can help.
Any suggestions anyone?
marcoma
Find all posts by marcoma
12-29-2012, 03:08 PM
RGTFanatic
Posts: 6,216 - iTrader: (
Re: EMG wiring problem
Hey Marcoma, welcome to Jemsite!!!
What kind/year of guitar is this in? and what type/brand of switch are you using??
Have a read through AlaskaBat's thread....... pretty much every resource for wiring and schematics is in here:
http://www.jemsite.com/forums/f35/an...ad-110579.html
__________________
RGTFanatic
Visit RGTFanatic's homepage!
Find all posts by RGTFanatic
12-29-2012, 03:46 PM
marcoma
Its a custom guitar, jackson body I think.
I'm looking through that link right now.
Thanks
marcoma
12-29-2012, 03:53 PM
marcoma
I dont think I can find the answer yet. Those links were good but didnt have the answer I was looking for.
marcoma
12-29-2012, 04:27 PM
LonePhantom
Posts: 7,333 - iTrader: (
Reviews: 120
Follow the instructions that show a volume and tone, just omit the tone control part when you wire yours.
LonePhantom
Visit LonePhantom's homepage!
Find all posts by LonePhantom
12-29-2012, 05:07 PM
marcoma
Thanks, I will try that.
marcoma
12-29-2012, 06:55 PM
AlaskaBat
Contributor
Posts: 8,948 - iTrader: (
Reviews: 98
marcoma
Yes--it's that simple.
Just omit any components you are not using.
AlaskaBat
Find all posts by AlaskaBat
01-14-2013, 07:13 AM
marcoma
I still cant get this right, here's my setup:
Neck: EMG 89
Middle: EMG SLV
Bridge: EMG 89
There is space for one master volume and one master tone. I cant fit the EMG 5 way switch in the cavity so I have to use a non EMG switch which leaves just enough space. This means I have to do a bit of soldering on the switch but that is not a problem.
As the 2 EMG 89 pickups have pots to switch from single coil to humbucker I am lost as which of the connectors to use, I cant seem to find what the connections H1 to H5 do to be able to make sense of it.
Can anyone advise on how I should connect things?
marcoma
01-14-2013, 10:56 AM
Fastmerc
Posts: 508 - iTrader: (
The easiest way to figure out what you want is to email emg support. Rick will usually get back to you the same day. Your post here is a little confusing on what your are trying to accomplish. I would list all the parts you are using with pics and how you want the set up to be. From what Ive pieced together you want
bridge 89 to be coil split with a push pull tone pot
single in the middle
neck 89 to be coil split with a push pull volume pot
with pickup selection using a standard 5 way switch?
I am also assuming you are talking about the newer quick connect systems?
Fastmerc
Find all posts by Fastmerc
01-14-2013, 12:14 PM
marcoma
Yes, exactly right. I emailed EMG earlier today and am waiting for their response.
marcoma
01-16-2013, 07:36 AM
marcoma
Fastmerc
I haven't received a response from them yet, do you know of a direct email I can send the question to?
Thanks
Marco
marcoma
01-16-2013, 09:14 AM
Fastmerc
Just
Tech@emgpickups.com
, that is the one I have replies from.
Fastmerc
01-16-2013, 09:17 AM
marcoma
Ok, thanks I'll try that
marcoma
89 pickup
emg
slv
Wiring problem? HELP
Gibson75
Pickups & wiring
06:00 PM
Problem Wiring
Madman87
Pickups & wiring
12:45 PM
wiring problem
david destroy
Pickups & wiring
02:34 PM
I have a wiring problem.....
jeff l
Pickups & wiring
08:27 AM
EMG wiring problem, please help!!!
mingincorn
Pickups & wiring
04:09 PM
07:36 AM
