I'm installing 2 new PUs on my rg550, Air Norton/ Steve's Special
I'm wiring it with a 12 point 3 way
toggle switch. I found a wiring
diagram here
http://www.ibanez.com/wiring/wire.asp?y=1996&w=JPM100]JPM wiring[/url]
After wiring I only get sound comming out from the neck and middle postion but nothing from the bridge, not even noise. I also find my volume and tone pots a bit noisy, should I get new ones or not?
I wired it and double checked if I made any mistakes, to see if any wires has been short circeted. Am I doing something wrong with the 3 way toggle? Does it matter which way I wire the toggle, I'm not sure if both sides are the same or not. I'm using a Dimarzio 12 point 3 way toggle.
Please can someone help me out.
Thanks
Alan
