Pickups & wiring
First pup replacement...need a pep talk...
Pickups & wiring
03-21-2008, 04:21 PM
chaos731
Posts: 489 - iTrader: (
OK, so I'm about to perform my first pup replacement.
I'm taking the V8 out of my beloved stock 2000 RG570GN and slapping an EVO2 Bridge in there.
I have several different wiring diagrams from varying sources (and with wildly varying degrees of quality; from Ibanez' stock pickup configuration diagrams to Dimarzio's "kindergartener drew it with crayons" version), and while it more or less makes sense to me, I'm still experiencing this (possibly irrational) feeling of fear and trepidation.
So, pretty please, with freakin' sugar on top, would some of the sage scholars here give me a pep talk? I don't want to totally screw up my RG. Again, irrational, but there it is...
Any help/advice/tips/tricks would be appreciated in the extreme.
chaos731
Find all posts by chaos731
03-21-2008, 04:30 PM
Algiman
Posts: 2,553 - iTrader: (
Re: First pup replacement...need a pep talk...
Take your time, let the soldering iron get fully up to temperature before you begin, and remember that wiring isn't some kind of permanent mod - you can always re-do it.
Algiman
Find all posts by Algiman
03-21-2008, 04:44 PM
jaxadam
Classified Watchdog
Posts: 3,043 - iTrader: (
Be careful. Don't cut the wrong wire, or it could be your a$$...
jaxadam
Find all posts by jaxadam
03-21-2008, 04:46 PM
losgatosrg350dx
Posts: 848 - iTrader: (
read the dimarzio ones...the coloring of the wires are all different for all pups
so just use the 5 way switch as a refrence, make sure u got the spring side properly identified, and the prongs on the pots.... use dimarzios diagram its actually really easy and perfect, but make sure your runnign the same comfiguration as u are runniing now
then solder the tip of the wire, just a 1/8 inch needed....and clean ur solder tip with a wet rag, use a small 5/10 wat iron, if u use a hot iron not meant for small soldering you will destroy and melt the conductor inside the pots...those mechanism are sensitive and you can ruin them, that is why they make special non corosive cleaners to clean pots.....
then take you wire, and put it NOT in the hole of the lead on the pot of switch, and just lean it on the prong
then dap a tad but of solder(flux core in this case(try not to use lead becasue it attracts buzzing and stuff--use silver solder)) and then with that dab of solder then move it over to the prong with the wire, and it should roll right over on the tab - nd heat it up, fast enough for the whole thing to be covered in solder--then remove it, and blow on it with ur mouth to cool it quickly because the wire can still not be secured-this is a easy way, you dont need alot, you want to keep the pots as cool as possible...and dont use a very hot iron
did i miss anything..oh yeah in between coatings, always use a moist rag to clean off alllllll solder on the iron....make sure its clean everytime u solder...this will transition to the clarity of the sound as if the soldered part is "unclean" it developes lots os resistance
losgatosrg350dx
Find all posts by losgatosrg350dx
03-21-2008, 04:49 PM
chaos731
jaxadam
Thank you for that.
From the very bottom of my warm, fuzzy little heart. Thank you.
chaos731
03-22-2008, 01:03 AM
rty13ibz98
Posts: 1,811 - iTrader: (
34
more like just don't cut the wire. leave the pickup length as long as possible. then, if you make a mistake, you'll have slack to fix your mistakes. pre-tin your wire/lugs before solder connections. it will make flowing both components easier. use a 25-40w soldering iron. any less will not get hot enough. any more will fry the insulation. i use a 100w gun for soldering a ground to a
trem claw
, but that's it. keep a small dmap sponge around to wipe off excess solder and clean your iron's tip when it gets dirty. these are things i typically remember whenever i solder.
rich
rty13ibz98
Visit rty13ibz98's homepage!
Find all posts by rty13ibz98
03-22-2008, 01:20 AM
losgatosrg350dx
rty13ibz98
more like just don't cut the wire. leave the pickup length as long as possible. then, if you make a mistake, you'll have slack to fix your mistakes. pre-tin your wire/lugs before solder connections. it will make flowing both components easier. use a 25-40w soldering iron. any less will not get hot enough. any more will fry the insulation. i use a 100w gun for soldering a ground to a trem claw, but that's it. keep a small dmap sponge around to wipe off excess solder and clean your iron's tip when it gets dirty. these are things i typically remember whenever i solder.
rich
i have a 5-15 watt circuit iron, its a expensive one, i use it on 10w setting, but like some other irons do need a higher vlaue, mine gets the whole thing hot as hell mega fast, maybe its just mine, so yeah go with a 25-40w probably
losgatosrg350dx
trem claw
wiring diagram
replacement for ibanez lo trs?
do original floyd rose work as replacement of jackson jt580
edge pro stud replacement?
how much would a fretboard replacement cost
Stanley Jordan - Street Talk - Live at the Letterman show 88
sr505 direct replacement pickups and bridge
id
Pickups & wiring
03:52 PM
FS: RG-7 replacement body (mahog/maple/bubinga)
jim777
09:39 AM
what would u pay for replacement bodies and necks??
Duff Beer Man
09:01 PM
Jem Talk!
fono22
01-25-2006
05:39 AM
Replacement Trem arms (in the UK)
weserman
Tech: Setup, Repairs and Mods
10:05 AM
07:14 AM
