Gain Boost Pot? - Jemsite
post #1 of 7 (permalink) Old 01-17-2012, 12:33 PM Thread Starter
Gain Boost Pot?
I just wonder if there's any good gain boost push/pull pots for dimarzio pickups?
Kind of like the Emg Ab-afterburner push/pull pot.
Thanks.
reneg is offline
post #2 of 7 (permalink) Old 01-17-2012, 01:03 PM
Re: Gain Boost Pot?
check out
www guitarpartsonline com
sebastian is offline
post #3 of 7 (permalink) Old 01-17-2012, 01:30 PM
Re: Gain Boost Pot?
I used the Artec one in a bad guitar just to try it out,
thought it was good but the guitar wasnt great so i didnt play it much.
Artec EXP Onboard Active Guitar EQ Expander
or there is the QDD if you want more gain.
I gave up on them because its like putting an overdrive pedal in a guitar,
I have lots of pedals already so why do a want another one in my guitar ?
LostInRockFormations is offline
post #4 of 7 (permalink) Old 01-17-2012, 03:47 PM
Reviews: 120
Re: Gain Boost Pot?
From memory you can use the EMG Afterburner with an pickups. Just get that if that's what you want.
LonePhantom is offline
post #5 of 7 (permalink) Old 01-17-2012, 04:15 PM
Re: Gain Boost Pot?
Lee Jackson makes one
http://www.leejackson.com/CrackpotzE...itchBoost.html
Chewy5150 is offline
post #6 of 7 (permalink) Old 01-17-2012, 04:21 PM
Re: Gain Boost Pot?
I am curious why you want it,
I have the EMG 81/85 set with the boost switch and the boost seems fairly pointless to me, every time I use it I have to turn the gain down on my pedals or amp or it sounds too harsh or distorted.
I cant imagine you will get a better boost from a switch than a decent pedal or amp,
maybe its easier to carry but a pedal isnt so big.
post #7 of 7 (permalink) Old 01-19-2012, 09:01 PM
Re: Gain Boost Pot?
I reckon if you're a straight into the amp player loving passive tone, the onboard overdrive is a fantastic way to change your sound up quickly. Fantastic for the living room, and still kind of practical for live. - I see these pots as character changers to make a clean pickup nasty.
If you're going through a massive pedal collection however, getting the input gain just right could become hell live. In that situation, I think I would want a noise gate/ compressor/ volume pedal on the floor set to compensate for the extra gain, and the problem with that *could* be volume drop making the onboard gain booster redundant.
It would be very, very interesting to wire up a passive equipped guitar in such a way as to use both traditional passive controls, AND the new Duncan Blackout preamp. If it's possible to wire a guitar in that fashion I will definitely try it with a JB/59 or an ALT8/59 setup to see what I get.
SpikeSocietySucks is offline
dimarzio , gain boost
Human Verification
F/S EMG PA-2 gain boost switch ( solderless) metalguy Classified Ads: Guitars and Gear 0 08-17-2010 10:27 PM
Boost/Gain Pedals Morbid Gear and Equipment 12 09-16-2007 06:46 AM
EMG boost in RG? RG3120 J-Custom, USA Custom & Prestige Ibanez Guitars 1 11-01-2005 03:39 PM
Looking for a boost... Jammy Gear and Equipment 4 01-20-2003 12:47 PM
Gain Boost - What to you guys use? carlos seo Gear and Equipment 21 04-02-2001 07:24 AM
