Old 09-22-2005, 02:49 AM
superhairycamel  is offline
Posts: 338  -  iTrader: (0)
Grounding Wire
Ok so i have a cheap crapocastor that im doing up and i accidently pulled the grounding wire out i dont even know when, anyway i found it and i dont know where to solder it on, i dont know which pot. so heres the set up from looking from the back of the pickguard.
Volume pot
Tone Pot
Unput Jack (Yes its on the pickguard)
It has only the one humbucker.
So where do i connect the ground wire?
Ps all of the wiring apart from this is in place
Old 09-22-2005, 11:02 AM
rty13ibz98  is offline
Re: Grounding Wire
on any pot...they are all connected(or should be). typically, the ground wire from the bridge goes to the volume pot. don't take that as law, as all of the grounds should be connect to a singular ground point.
rich
Old 09-22-2005, 12:05 PM
buddroyce  is offline
Re: Grounding Wire
Look for a spot that other grounds are connected to and just solder it onto that.
How to wire this humbucker? kickz28 Pickups & wiring 8 01-08-2004 06:51 PM
Help me wire new pups for my SZ520 PekkaM Pickups & wiring 13 05-07-2003 03:33 PM
Help! *New pickup sounds like doo-doo ashlock Tech: Setup, Repairs and Mods 9 05-22-2002 05:55 AM
extra (?) ground wire - is it needed? GreasyKid Tech: Setup, Repairs and Mods 3 02-23-2002 11:35 PM
Replacing a 2 wire pup(V8) w/ a 4 wire (evo) - Installing an floydJ Tech: Setup, Repairs and Mods 3 08-07-2001 01:59 PM
