Okay guys check it out. Here is where I am at on my frankenstein RG;
Until I find/decide on a bridge position pup, I am installing a V1, an S1, and another 3 wire pickup in the neck position (I think its a SD of some sort).
So the problem I have is this; I cannot find a wiring diagram that matches exactly all of my components, with the main issue being the 5-way switch. And since I am not a pickup installing genius, I would really just like to be lazy and fine the exact schematic.
The diagram from Ibanez that fits my set-up (minus my switch) is here;
http://ibanez.com/support/wiringdiagrams.aspx
Enter a 2007 RG350DX - That is my config (again, without that switch)
For a diagram that shows the type of switch I have (not solid state, and except mine is a 5-way, not a 3-way), punch in a 98 RG1608.
That rig has 5 wires per pup, mine has 3.
And thank you for your time.
