Pickups & wiring
H-S-H series/parallel switch help please :)
Pickups & wiring
Page 2 of 3
01-12-2010, 05:54 PM
Sponge Monkey
Posts: 115 - iTrader: (
Re: H-S-H series/parallel switch help please :)
vai n maiden
Consider that diagram stolen! I've been trying to work out how to have both parallel/series and the standard position 2/4 splitting on one guitar. Now you've worked it out for me - cheeeers!
uhh... 2 and four won't split the humbuckers...
that was our problem, and we resolved to just deal with it :P
also remember, on this diagram, the up position on the DPDT is series, and down is parallel.
i prefer down as series, and for this you'll need to flip the DPDT upside down ^^ (on the diagram!)
Sponge Monkey
Find all posts by Sponge Monkey
01-13-2010, 04:51 PM
vai n maiden
Posts: 215 - iTrader: (
Reviews: 3
Oh - I thought the splitting would work in pos 2 and 4 when the switches are set to series. If that's not the case forgive my silliness!
I'll be using mini switches instead of push pull pots so the direction doesn't matter too much to me!
vai n maiden
Find all posts by vai n maiden
01-13-2010, 05:13 PM
Vim Fuego
Posts: 908 - iTrader: (
vai n maiden
You will get split single coils in series mode in 2 and 4. In parallel mode when arguably you don't need the split you'll just get the parallel coils with the middle pickup.
Jim
Vim Fuego
Visit Vim Fuego's homepage!
Find all posts by Vim Fuego
01-13-2010, 05:18 PM
Sponge Monkey
yeah that's what i meant.
it will split in series, but it WONT split in parallel
Sponge Monkey
01-13-2010, 08:25 PM
vai n maiden
Reviews: 3
That's all I need! I'm a wiring dunce so I couldn't work it out myself! My switches arrived today at work. Supoib.
vai n maiden
01-16-2010, 07:38 AM
Sponge Monkey
Ok err... folks. i tried this last night aaanndd.... well, it doesnt work
haha! a real pain for me #_# ill take a look at it when i have more time. sunday probably.
Sponge Monkey
01-17-2010, 04:51 PM
vai n maiden
Reviews: 3
Uh - oh. I left my strat with a tech and this diagram.
vai n maiden
01-17-2010, 06:03 PM
Sponge Monkey
aha! oh dear! maybe it'll be ok, it may just be my poor wiring.
the main problem is, no output in parallel mode for positions 1 and 5. but im sure if he's a good tech he'll get it!
Sponge Monkey
01-19-2010, 02:31 PM
chafinlw
Posts: 3 - iTrader: (
Hey, Spnge Monkey, don't let the solution go unposted. I'm in the process of putting together a similar wiring scheme - with DiMarzio Evos in the bridge and neck and a SC in the mid position, push pull pots to coil tap the 2 Evos, and a 5-way switch to direct the action. I'm really pretty much a spedhead on this stuff, but I can read a schematic, do a decent job of soldering without it looking like it was done in Dresden during the firestorm, and am looking to wire this thing up for my kid kinda like Vai's rig, but with coil tapping. (Is that redundent?) I'm really looking for guidance on how to do this stuff, and this is the best stop I've made on the web so far. Looks like your first schematic would do what I'm trying to do - assuming the colors are right for the DiMarzios. Any advice folks?
chafinlw
Find all posts by chafinlw
01-20-2010, 11:36 AM
djohns74
Posts: 580 - iTrader: (
chafinlw
Hey, I just realized that to start with, the OP here was trying to achieve a
series/parallel
switch along with standard Ibanez 5-way wiring, not a coil tap, which should be relatively simple. So I don't think any of these diagrams will be appropriate for you. I found the following in another thread, which should do the trick:
The red and green wires in the diagram should be the only addition to the existing wiring. This shuts off one coil of each humbucker when the switch is pulled up, so you get single coil sounds in the 1 and 5 positions. Positions 2-4 are unaffected by the push-pull as there is already automatic coil-tapping in those positions.
Now, as for whether this is worthwhile, that's up to the individual player of course. I personally don't care for coil-tapped humbuckers by themselves that much. You tend to end up with something that reduces the output level a lot, which of course is expected, but I think it reduces it to the point that it's ever lower than a standard single coil pickup. In addition, guitars with humbuckers tend to have 500K pots, so a single coil, especially in the bridge position, can tend to sound really bright, to the point of being somewhat harsh.
I'm not really a big fan of single coil sounds in general, so my opinion in the matter should be taken with a larger grain of salt than usual. As such, I'd have a hard time recommending an appropriate replacement middle pickup, though if you're going with Evos, I should think the Evo middle (sometimes called the ISCV2) might be a good bet. Someone else might have more thoughts on that issue.
As for where to get parts, there are a couple of good resources online. I generally like Stewart-MacDonald (
http://www.stewmac.com/
) even though some of their stuff is a little overpriced. For something small like pots and switches, the difference, if any, is negligible. You may only need to get a single push-pull pot, found
here
djohns74
Find all posts by djohns74
01-20-2010, 01:52 PM
Sponge Monkey
Yeah, i was going for parallel switching on each humbucker with standard ibanez 5 way switch.
it didn't work :P
i WAS gonna have a split coil option like you're going for but decided that parallel switching would be more worthwhile.
sorry i can't be of any more help, and goodluck!
Sponge Monkey
01-20-2010, 03:13 PM
Vim Fuego
I'm shure the scematic should work, have you got the coil wire colours correct?
Why not check the schematic with the guys at Bareknuckle?
I don't suppose you're anywhere near the South West UK are you?
Jim
03:13 PM
. Reason: Typo
Vim Fuego
01-20-2010, 05:02 PM
chafinlw
Hey, thanks for the help - I'll let th' rotten kid go sit with a coil tapped guitar and see if he likes the sounds that come out. He's got a Jem77V to compare it to. Now about that switch - is it a standard one or is it an Ibanez designed for the JEM?
chafinlw
29
01-20-2010, 05:44 PM
Sponge Monkey
The 5-way or the DPDT?
the DPDT is just a push/pull i ordered from bareknuckles for about Ł7.50
and the 5-way is a standard 5 way that was already in my RG.
and @Vim, nope im the other side: south east :P
Sponge Monkey
30
01-20-2010, 05:56 PM
Vim Fuego
Ok too far for me to check it for you...
@chafinlw: The Jem has a different switch, or at least the new ones do, it should be possible to work out the equivalent schematic. If not I can paste the jem version if that helps.
Jim
Vim Fuego
Page 2 of 3
h-s-h
series/parallel
what s series ibanez did herman lee play
make an ibanez rg series sound like a strat?
what is pu selector switch
how much is a fender stratocaster japan series
how much is new ibanex rx series pictures
Series/parallel on rg570
rublalup
Pickups & wiring
01:31 PM
Ibanez H-H 5-way switch parallel / series
F242
Pickups & wiring
07:39 AM
Series/Parallel switch on a strat?
jm1681
Pickups & wiring
08:33 AM
Series and parallel with a EP1112 help!
marianozz
Pickups & wiring
07:49 PM
Series/parallel madness!
Big Job
Pickups & wiring
01:04 PM
01:37 PM
