Old 03-09-2008, 01:24 AM
shreddersymphony  is offline
Posts: 1,482  -  iTrader: (0)
Has anyone tried coil-tapping an Evo 2?
My new custom guitar's gonna have an Air Norton neck, Cruiser mid, and Evo 2 bridge. I know someone who tapped the Air Norton and said it had a GREAT tone tapped. Has anyone on jemsite tried/had an Evo 2 tapped? Curious as to how it'll sound, although I guess I'll find out by the end of the week.
Old 03-11-2008, 01:32 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Re: Has anyone tried coil-tapping an Evo 2?
Here's an easy way to do it if you(like me) never use the tone knob. Run the black and white wires that get soldered together(for standard humbucking) and attach them to the center lug on the tone knob. Remove the cap and ground one of the outside lugs. When you roll the knob back, you bypass one coil. Works great and does not require any drilling or push/pull pot. Which outside lug you ground will determine which way goes to single.
Old 03-11-2008, 01:36 PM
screamndemon69  is offline
Posts: 5,676  -  iTrader: (12)
I tried a push pull pot (500k) to an EvoII and it worked fairly well. It had it installed on a single hum customized RG so I could get more than one different tone.
this is the axe it WAS installed in:
~Bones
Old 03-11-2008, 02:25 PM
Crazy_Guitar  is offline
Posts: 1,319  -  iTrader: (0)
Reviews: 4
I coil-tap my Evo 2 in a Super-5way wiring system. Haven't (nor will I) try it "alone".
Does it sound good?
Old 03-11-2008, 02:28 PM
It sounded a little thin (to be expected) but was a nice diference in tone since my axe only had the one humbucker.
~Bones
Old 03-11-2008, 04:23 PM
Ah mine's gonna be wired straight into my custom guitar , push pull.
I'm not hopin' for any kind of amazing cleans (tapped Air Norton in the neck and Cruiser middle will do that just fine), I was just wondering what kind of a clean sound it gives ya, glassy, shimmery, etc. I'll let the board know on Thursday when I pick this bad boy up!
Old 03-11-2008, 04:46 PM
losgatosrg350dx  is offline
Posts: 848  -  iTrader: (0)
~Bones
try using a 1 meg instead.....
Old 03-11-2008, 04:49 PM
when u wire it up, try to wire the single coil u want to work, strait into a (example) 1 meg volume pot
and play it, if it sounds thin on teh single coil then theres no need to install a pushpull coil tap cuz youll most likely want just the hb mode cuz u like those pups u selected
i say try a coil on its own, wichever one u want durring the coil tapping, dont like it, dont wire it
but if u want to have a set of pups of ur desire...then id recomend wiring with coil tapping becasue if u tap one coil from ur neck and one from ur bridge, the two pups with mismatched signal output and impedence always give to great tone
just like those humbuckers with one coil hotter than the other....always a good thing for some players
air norton, air norton neck, coil tap, coil tapping, custom guitar, norton neck, pull coil, pull coil tap
Phase Reversal & Coil Tapping in RG520 mythos1980 Pickups & wiring 1 02-22-2008 01:26 AM
Coil Tapping Jem Humbuckers TremoJem JEM and Universe Guitars 6 01-11-2007 12:56 PM
Coil Tapping Jem Humbuckers TremoJem Pickups & wiring 0 01-10-2007 07:54 AM
Lesson 13: Tapping overview - right hand technique jem7vwh Guitar Lessons & Music Theory 19 01-11-2005 11:00 PM
Coil tapping the evo's on my 7vwh - can it be done? darthpolster JEM and Universe Guitars 1 03-19-2002 12:17 AM
