Pickups & wiring
Help, EVO DP158 - does it really suck this much?
Pickups & wiring
03-14-2006, 05:33 PM
Jaden
Posts: 2,464 - iTrader: (
Help, I have an RG548 with a DP159 in the bridge, to compliment that pickup I bought a DP158 for the neck.
The
bridge pickup
rules !
the
neck pickup
sucks....! its MUCH worse than the V7 I took out of my RG
I wired it to the spec, that is
Green and Shield - Ground
White and black together to the selector switch
red - to the "hot" side - or again to the selector switch.
its great with a clean tone but as soon as I crank on any distortion or overdrive it starts to mud up really bad.
someone please tell me ive made a stooooooopid wiring error cos otherwise that pickup is going straight to evilbay and the V7 re-installed
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
03-14-2006, 05:56 PM
Ant1981
Posts: 2,181 - iTrader: (
Re: Help, EVO DP158 - does it really suck this much?
You're wiring is right. But you've done something wrong that's for sure, cos I have the DP158 in a Jem, naturally, also in an RG and it sounds awesome.
Maybe your pickup is too close to the strings?
Ant1981
Find all posts by Ant1981
03-14-2006, 06:04 PM
Jaden
thanks man, I did try the
pickup height
between 6mm and 2mm (guesstimate) while fretted at 24. it didnt really make any difference
I only own 2 RG's so dont have a evo equipped JEMxxxx to compare the sound to.
I only know that its crap, ive checked all the electrical connections to make sure there are no shorts or anything stoopid and its all OK.
Jaden
03-14-2006, 06:25 PM
Jaden
Oh, and just to clarify, when installing the new DP158 I copied the wiring from the DP159.
Cutting the old pickups out and using the tails to make an in-line connection.
wire for wire the two pickups are wired the same.
Jaden
03-14-2006, 07:03 PM
brothersnowgone
Posts: 1,498 - iTrader: (
Reviews: 7
Could be you just got a bad pup? I don't know, I have no experience with wiring (or hearing) Dimarzio's. Also using the old wires from the original pup could be your problem(don't know, never done that). Maybe you just don't like how it sounds, if you could do a sound clip it may help others to determine whether you have a botched pick-up. Good luck either way.
brothersnowgone
03-14-2006, 08:05 PM
David McCarroll
Posts: 2,049 - iTrader: (
maybe the EVO is just too powerful for your overdriven
amp settings
David McCarroll
Find all posts by David McCarroll
03-14-2006, 08:30 PM
j.arledge
Posts: 1,804 - iTrader: (
30
well the evo neck is a little more compressed and is less powerful then a
paf pro
but that still makes me think somthing isn't right . Do you get any buzz from the pickup when it is selected ?
j.arledge
Find all posts by j.arledge
03-14-2006, 09:35 PM
Shredcows
Posts: 506 - iTrader: (
whatisshredding
Methinks its something to do with this.
You joined the red wire of the DP158 to an old wire? What abt the White and Black wires of the DP158?
Can you do a tap test with the DP158 on, in series? Pup selector all the way up. Take a metal object, an allen key, and tap the polepiece of the DP158, check if both coil's pole pieces are working.
Shredcows
Visit Shredcows's homepage!
Find all posts by Shredcows
03-15-2006, 08:44 AM
Jaden
thanks to all, I have tried the tap test and its OK, my soldering is pretty good so im not worried about the physical connection. there is no buzzing or hum when the pickup is selected.
Its possible that David McCarrol is right and im just giving it too much overdrive, but Dimarzio rate it a medium
output pickup
(whatever difference that makes). Ive tried using the kind of rock settings that I would use with the bridge pickup and that is a big no-no.
when I tidy the sound up a bit it gets a lot strattier than I expected but is pretty crisp with a nice edge to it, I think I just wasnt expecting this much muddiness.
Im not experienced at changing pickups about so it could just be my expectations were a bit off, especially after the bridge was such a killer tone.
Shredcows - the black and white wires are soldered together and go to the selector switch along with the red wire.
any other ideas would be appreciated!
Jaden
03-15-2006, 10:54 AM
nickcoumbe
Posts: 2,417 - iTrader: (
Reviews: 34
This is interesting as most many people seem to prefer the
neck evo
to the bridge evo.
Maybe it's a problem with the volume pot itself. I understand that the ibanez standard issues aren't that well regarded (by my tech at any rate). Maybe there is some mileage in looking at replacing that.
It just breaks my heart to think of someone putting a v7 back in to a guitar.
nickcoumbe
Visit nickcoumbe's homepage!
Find all posts by nickcoumbe
03-15-2006, 11:10 AM
Jaden
yea, I thought that I would use the neck more than the bridge, sigh..
if the volume pot was a problem, it would affect both the pickups (i'd assume)
in any case, I think i'll replace it with a Dimarzio.
[It just breaks my heart to think of someone putting a v7 back in to a guitar.]
dont worry, that V7 is going nowhere near my RG again
Jaden
03-15-2006, 11:24 AM
Shredcows
hmmm... strange strange strange! Oh well.... perhaps its a faulty pup? Did you check ths pup's readings with a multimeter?
Shredcows
03-15-2006, 02:25 PM
Gex
Posts: 962 - iTrader: (
Ah, V7's arent THAT bad. Not as bad as those V8s.
Gex
Find all posts by Gex
03-15-2006, 02:28 PM
Jaden
I havent checked the coil resistance yet, my meter is at work but I will check it at the weekend.
according to Dimarzio the coil resistance should be 13.04 ohms.
Ive been checking and rechecking everything tonight, changing my amp settings and nothing works, I even plugged in an old RG450 with a no-name pickup on at the neck and it sounded loads better than the Dp158...
Jaden
03-15-2006, 02:54 PM
Jaden
Gex
I have to agree, the V8 sucks ass big time, the V7 gets too muddy with overdrive but sounds pretty good when clean.
I just wanted to complete the EVO set, considering thier reputation I didnt think I could go wrong.
never mind that, Im busy ignoring my wife and family in pursuit of a decent tone out of this pickup, so far Ive found that as long as you dont turn up your bass or mid too high on the amp you can drive the hell out of it !
Im running an Ibanez MT10 Mostortion pedal as a pre-amp and its looking more promising.
cant stop the damn 158 from giving that strat twang when you pick though.
Jaden
amp settings
bridge pickup
clean tone
equipped guitar
keeley mod
neck evo
neck pickup
neck pup
output pickup
paf pro
paf pros
pickup height
does boss ps5 suck tone?
do schecter guitars suck?
Marshalls suck with gain!
RSVampire
Gear and Equipment
52
11-10-2008
07:34 PM
Wow I suck at playing tab / sheet music!
red5
Players, Bands, People, Music & Tours
04:13 PM
Do Chicago Bands HAVE TO suck?
elcid
Off-topic / Miscellaneous
50
12-11-2005
11:06 AM
I suck at soldering!!! - any tips or instructions?...please?
oop
Tech: Setup, Repairs and Mods
04:30 PM
12:11 PM
