Old 08-04-2006, 09:45 PM
coolchrisuk  is offline
Posts: 4  -  iTrader: (0)
HELP!! Installing FRED & PAF Joe into my RG2570EX
Hello,
I have just purchased a FRED and PAF Joe to go into my RG2570EX replacing the existing Dimarzio/IBZ humbuckers. I followed this cct diagram..
http://www.ibanez.com/wiring/wire.asp?y=2004&w=RG2570EX
and basically just replaced the old wires with the new ones (same colours).
Tested all joints and components with a multimeter - all good - plug into amp ... and mid single coil is dead.... and fred and paf are giving broken, quiet, crackly output..... Please help!!!
Old 08-04-2006, 10:46 PM
j.arledge  is offline
Posts: 1,804  -  iTrader: (30)
Re: HELP!! Installing FRED & PAF Joe into my RG2570EX
go back and check all your solder joints over , even the slightest single strand of wire can effect the sound . Switches can some times be difficult to work with because of how close together the terminals are .
the single coil is dead ? Did you mess with it when you put the other two pickups in ?
make sure you didn't loosen up anything else and make sure that the bare ground wires from both pickups isn't touching anything , i usually put electrical tape over them to make sure they dont touch anything but the ground .
Old 08-05-2006, 05:38 AM
Ok thanks for the fast reply! I shall get my finest tooth comb out right now! I didnt mess with anything single coil like..... just unsoldered both reds and black/whites from the 5 way and the green/bares from the volume pot case. Then replaced each wire one at a time with the new one. When reading the dimarzio wiring instructions i noticed it mentioned just soldering white and black together and setting aside.... not connecting to the 5 way like in the diagram???
Old 08-05-2006, 07:31 AM
ROTFL!... well sorta mixed emotions.... yes everything is working ... it's a long story but im gonna tell it cos its funny and well... stupid!..It has taught me to trust my instincts and soldering techniques!
After trying different combinations last night I had no luck.. went to bed, got up... decided to rewire the two pickups according to the wiring diagram again. Tested everything... plugged her in... still no luck!.... Rang 3 music stores ... no techies in today... so I thought ill keep trying... then I thought..."what if" .... You see I run an Alesis microverb rack unit through my amp. I had unplugged it to use the extension for my soldering iron!.... so i unplugged the FX loops and HEY PRESTO!!! shes-a-working!!
Don't make the same mistake I did. Trust your instincts and your multimeter!
Thanks for your quick reply anyways dude.
Im off to scream out some Satch licks
Old 08-05-2006, 11:07 AM
dont worry man i have had stupid crap like that happen to me too . many times
music store, paf joe, wiring diagram
Dimarzio Fred in the bridge ?? Hmmm ibanezcollector Gear and Equipment 8 04-03-2006 02:37 PM
Fred for Rhythm? pedalinbob Pickups & wiring 6 08-08-2005 05:36 AM
Gentlemen A new FRED for a Friend now i need help! Jslegacy Pickups & wiring 3 06-01-2003 01:55 PM
Recommendation for S1520 owners: DiMarzio FRED and PAF Pro gitarrero Pickups & wiring 12 04-21-2003 05:01 AM
Help! New pickups in JS100 Sound bad? - PAF pro and Fred sou Voodoosoup JS (Satriani Model) Ibanez Guitars 6 03-27-2001 08:27 PM
