Pickups & wiring
Help me wire new pups for my SZ520
Pickups & wiring
05-06-2003, 10:38 AM
PekkaM
Posts: 428 - iTrader: (
I ordered
Seymour Duncan
JB and 59
neck pickup
for my SZ520. I didn't take 4-connector models but normal ones and here's what I got:
The upper one would be 59 neck with only one grounding covering and one conductor inside that. The lower one is JB cable with 5 conductors (red, black, green, white and metallic). Why are they so different?
Now below is what the wiring in SZ520 looks like:
From bridge there are coming white wire to volume pot, red and metallic are grounded to the same pot and black and green conductors are soldered to one pin in 12-pin 3-way switch.
From neck there's green wire to neck volume pot, and thick black grounded to the same pot. Red and white wire are connected to the switch.
How should I wire my two new pickups? I don't even need two separate volumes, just one with neck, bridge and both switching.
Thanks in advance.
PekkaM
Find all posts by PekkaM
05-06-2003, 04:39 PM
Mr Orange
Posts: 448 - iTrader: (
Go check out Duncan's site for schematics and color codes.
The basic stuff is that you wire ground wire behind the vol pot and hot to switch.
Otahan raahalliseesti...
Mr Orange
Find all posts by Mr Orange
05-06-2003, 04:43 PM
PekkaM
Mr Orange
I got the schematics with pups but they look nothing like what's inside my guitar
Ibanez has also schematics but not for 2003-models
Kyllä tässä rauhallisia vielä ollaan
PekkaM
05-06-2003, 04:54 PM
PekkaM
http://www.seymourduncan.com/website...way-w-spl.html
This seems similar.
So I should solder the wrapping from neck pickup to ground and black to neck volume pot?
The colors of wires from bridge pu seem different between Ibz and SD
pickups.
So next I solder black from bridge pu to volume pot and green and bare to ground (green and black in Ibz)?
The wires soldered in my photo to switch are those "solder together and insulate"?
What is done on SD schematic to red and white of neck pickup? Do they match the green/black or red/bare -pair in my photo? I don't want
coil split
so should they be sodlered together or left separate?
Does it really matter where I ground conductors?
Man... I thought this was gonna be easy since I already had soldering experience...
PekkaM
05-06-2003, 10:46 PM
SV300
Posts: 94 - iTrader: (
VERY confusing.
The SD "Solder together and insulate wires" are the series link wires. Basically, solder them together, and youll get a full humbucker in series. Solder them together and ground it, youll split one coil. Connect them to hot, youll split another coil.
The ibanez wiring... just got me lost!
On the neck pickup, the green wire is the hot output? Im guessing this... since its attached the the volume pot. On the bridge, its the white wire which is the hot output. I believe their buckers arent in phase with each other, so they swap around the lead wires??
This leaves the red wire, which *could* be a ground from the pickup baseplate, but whyt eh feck is it connected to the 3 way switch on teh neck pickup??
If i were you, id give up, and rewire the damn thing!!
SD codes:
4 conductor (JB comes standard as a 4 conductor)
Bare - ground
Green - ground
White & Red - series link
Black - hot
2 conductor (59)
Braid - ground
the other wire - hot.
Hope this helps.
SV300
Find all posts by SV300
05-07-2003, 01:32 AM
PekkaM
SV300
VERY confusing.
And it looks like they've tried to solder something to all the connectors on the switch at least onece...
What are all those connectors for anyway? How does a three way switch work?
SV300
I'll probably do that since it seems much more easier following the SD schematic. I'd just like to know how to translate the connections to the switch shown in schematics to actual one.
PekkaM
05-07-2003, 06:42 AM
Mark DY
Posts: 562 - iTrader: (
Well now...
Pekka - all I did was replace the
bridge pup
with a DiMarzio - I spliced it in when I saw the wiring for the SZ. The Ibanez wiring color scheme was different than DiMarzio - red was ground in the Ibanez instead of green (I think). I also switched the volume pot and the bridge tone pot to have the volume closest to the strings.
Sorry I couldn't be more help on this one.
Mark
Mark DY
Find all posts by Mark DY
05-07-2003, 06:50 AM
PekkaM
Actually I'm thinking of taking all wiring out and rewiring it to something like this:
http://www.seymourduncan.com/website...1vol_3way.html
I never use tone pot and two volumes actually irritate me and cause me occassionally to switch to muted mic when recording.
I already borrowed a multimeter to find out how that switch functions.
Thanks to all for help!
PekkaM
05-07-2003, 08:06 AM
SV300
The switch looks like it may be a 4 pole 2 throw switch.
x x x
x x x
x x x
x x x
My guess, would be htat in one position.. allt he poles in the center lug would be connected to one side of the pole, e.g.
x-x x
x-x x
x-x x
x-x x
In the mid position, im guessing itd be connected like this?
x-x-x
x-x-x
x-x-x
x-x-x
And in the other end, im guessing it could be connected as
x x-x
x x-x
x x-x
x x-x
Could be wrong. Hope you understand my diagrams!
SV300
05-07-2003, 08:30 AM
PekkaM
SV300
That was my initial guess too, I was just distracted by all the wires attached to it and all the excess solder on unused pins (wtf is up with that?
It looks like they've used excess pins as "wire together and insulate" or something...
Well, out with all that mess!
PekkaM
05-07-2003, 10:42 AM
PekkaM
Switch works something like this:
switch <-
x x-x
x x-x
x x-x
x x-x
switch ->
x-x x
x-x x
x-x x
x-x x
switch up
x-x x
x x-x
x x-x
x-x x
Well now that that's sorted out, some soldering is in order...
PekkaM
05-07-2003, 11:24 AM
SV300
*Makes mental note to never attempt to rewire a guitar with an ibanez 3 way switch without replacing it*
Honestly, it looks like they were a little tipsy after a few beers, and therefore decided to make use of any extra pins they could find
Good luck in designing your diagram! Still dont get why they cant go with the proven method (e.g. your good old LP style 3 way switch)
SV300
05-07-2003, 03:07 PM
PekkaM
Well it's done. Wiring may not be that beautiful but guitar looks and sounds even better
Second volume and tone are both bypassed.
More pictures here:
http://koti.mbnet.fi/~pmm/pics/sz520/
PekkaM
05-07-2003, 03:33 PM
Mark DY
Nice work - looks like Korean made still has a few dips, but...
Glad I didn;t do mroe than I did! I put a TZ in the bridge and left the
neck pup
alone since I never use it on this guitar (and it looks identical to the TZ).
Sweet top BTW!
Mark DY
bridge pup
coil split
neck pickup
neck pup
seymour duncan
HOW TO Paint & Wire Your Very Own 5150
how to wire a jb to sound like a strat
how to wire a stereo piezo pickup
how to wire Dimarzio PAF
how to wire a emg 707 pickup
01:22 AM
