Old 09-01-2009, 05:05 PM
Jibboom77  is offline
Posts: 39  -  iTrader: (0)
Help needed! RG570 w Fender dm50 switch
Hello! I bought recently an 1990 RG570PN, and I changed pickups to DiMarzio Breed (N) and Evo2 (B), middle is stock... But the problem is that the recent owner installed Fender DM50 5 way switch, which I haven't noticed since now, and since I did wiring according to DiMarzio schemes, you can only guess the result...
I tried to find some wiring schemes on Fender site, but they don't seem to work neither. So, can anyone please give me HSH wiring scheme with this switch? Tnx!!!
Old 09-01-2009, 05:29 PM
Re: Help needed! RG570 w Fender dm50 switch
Sorry, I just noticed I put this thread in wrong forum... Mods, please put it where it belongs or delete it...
Old 09-01-2009, 06:04 PM
Ayrton  is offline
What exactly are you trying to do?
What diagram did you use from DiMarzio?
Old 09-01-2009, 06:12 PM
I used standrard DiMarzio HSH diagram... I'd put a link here, but I don't have enough posts to do that...
And almost every diagram I found on Fender site using 8 pole switch...
And none works! I just want to have a standarg HSH configuration with coil tap on positions 2 and 4.
Old 09-01-2009, 06:15 PM
Ayrton  is offline
Did you buy a hum-canceling center coil to go along with your new humbuckers?
I posted the diagram in the other thread (other guy with the DM50).
You would use the same diagram.
Old 09-01-2009, 06:17 PM
Single is Ibanez S1, stock for this guitar. It has red, white and ground...
I think I'll just go and buy DiMarzio switch...
Old 09-01-2009, 06:19 PM
Ayrton  is offline
Easy, this is your diagram.
http://www.dimarzio.com//media/diagrams/C.pdf
There are still 8 poles, just follow it along.
Old 09-01-2009, 06:21 PM
Yes, this is DiMarzio diagram. Doesn't work with the bloody switch!
Old 09-01-2009, 06:28 PM
Ayrton  is offline
Ok, if you want to replace the switch, you can do the regular 4/4 style, or if you want to replace the single, a "super switch".
Regular
http://www.stewmac.com/shop/Electron...etails#details
Superswitch
Old 09-01-2009, 06:33 PM
I'll get DiMarzio regular 4/4 switch
But I don't understand why this fender's switch doesn't work?! That 4/4 sw should be some kind of a standard, right?
Old 09-01-2009, 06:42 PM
Ayrton  is offline
Either style is common, but the inline is more common in the east.
The number of reasons why your current switch does not work (assuming it is the switch) are endless.
If you think you have it wired correctly, and it still does not work, double check everything and then try a new switch.
Old 09-01-2009, 06:46 PM
I connected every pickup's hot wire directly on output and they all work. So, the pickups are ok. I managed to get (at one time) humbuckers on pos 1, 2, 4 & 5, but no single at all... I remember that some pins on switch were jumpered, but I can't remember which ones!
hsh wiring
Quesiton about corresponding ibanez 5 way switch diagrams for a fender 5 way switch GuitarEvan07 Tech: Setup, Repairs and Mods 0 06-19-2009 09:20 PM
Help needed with slightly different mega switch wiring Edoh Pickups & wiring 0 01-23-2009 04:08 AM
switch pedal idea - advise needed GeorgeSunset Gear and Equipment 0 06-25-2008 06:20 AM
Help - Guitar Switch box needed lhrocker Gear and Equipment 15 04-06-2004 04:37 PM
Intonation help needed on my Ibanez RG570 JimmyJ Tech: Setup, Repairs and Mods 11 01-22-2004 05:10 AM
