The jack is different...the stock JEM jack is a mono jack, whereas the EMG has and NEEDS the stereo jack. The stereo jack acts as a battery switch. When you plug in a guitar cable, the battery is engaged to power the pickups' preamps. If you wire the EMGs to the mono jack, the battery connection will always be on, and your batteries will last very shortly. Likewise, if you put in a stereo jack, and forget to unplug your cable, the battery is draining. Always unplug your guitar!
You can get stereo versions of the jack in a Jem at any repair shop or electronics parts store...take the original jack with you, and tell them you need a stereo version that's identical...
